I’d like to be able to login to one of the TX1 serial consoles from my laptop using a USB-to-serial crossover cable. Currently, I’m using minicom as the tty client on my laptop, and the J21 UART pins on the TX1 as described here http://www.jetsonhacks.com/2015/12/01/serial-console-nvidia-jetson-tx1/. All of the bootconsole processes log in minicom, but communication between the two devices appears to cease after the bootconsole is disabled. I’d like to know what changes I need to make (use a different serial port, or enable the correct tty) so that I can login to the TX1 via serial connection after it boots.
When I boot the TX1, I get the following output in minicom
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan 1 2014, 17:13:19.
Port /dev/ttyUSB0, 11:37:58
Press CTRL-A Z for help on special keys
[0000.191] [TegraBoot] (version 24.00.2015.42-mobile-ec3b827e)
[0000.197] Processing in cold boot mode Bootloader 2
[0000.201] A02 Bootrom Patch rev = 63
[0000.205] Power-up reason: on button
[0000.208] No Battery Present
[0000.211] RamCode = 0
[0000.213] Platform has Ddr4 type ram
[0000.216] max77620 disabling SD1 Remote Sense
[0000.220] Setting Ddr voltage to 1125mv
[0000.224] Serial Number of Pmic Max77663: 0x1401f4
[0000.232] Entering ramdump check
[0000.235] Get RamDumpCarveOut = 0x0
[0000.238] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.243] Last reboot was clean, booting normally!
[0000.248] Sdram initialization is successful
[0000.252] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.258] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.263] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.268] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.273] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.278] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.283] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.289] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.304] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.309] Platform-DebugCarveout: 0
[0000.313] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.318] Non secure mode. Disable rollback prevention
[0000.323] AOTAG Init Done
[0000.370] Using GPT Primary to query partitions
[0000.376] Loading Tboot-CPU binary
[0000.425] Verifying bootloader in OdmNonSecureSBK mode
[0000.435] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.442] Bootloader downloaded successfully.
[0000.446] Downloaded Tboot-CPU binary to 0xa0000258
[0000.451] MAX77620_GPIO1 Configured.
[0000.454] MAX77620_GPIO5 Configured.
[0000.458] CPU power rail is up
[0000.461] CPU clock enabled
[0000.464] Performing RAM repair
[0000.467] Updating A64 Warmreset Address to 0xa00002e9
[0000.484] Bootloader DTB Load Address: 0x83000000
[0000.501] Kernel DTB Load Address: 0x83080000
[0000.506] Loading cboot binary
[0000.600] Verifying bootloader in OdmNonSecureSBK mode
[0000.694] Bootloader load address is 0x8010fda8, entry address is 0x80110000
[0000.701] Bootloader downloaded successfully.
[0000.706] GPT: Partition NOT found !
[0000.709] Find Partition via GPT Failed
[0000.713] Find Partition via PT Failed
[0000.716] function NvTbootGetBinaryOffsets: 0x1 error
[0000.721] Error in NvTbootLoadBinary: 0x1 !
[0000.725] Next binary entry address: 0x80110000
[0000.729] BoardId: 2180
[0000.755] NvTbootI2cProbe(): error code 0x00045100 Error while read
[0000.761] Display board id is not available
[0000.766] dram memory type is 3
[0000.770] WB0 init successful
[0000.796] Bpmp FW successfully loaded
[0000.799] Set NvDecSticky Bits
[0000.803] GSC1 address : ff700000
[0000.806] GSC2 address ff63fffc value c0edbbcc
[0000.811] GSC2 address : ff600000
[0000.814] GSC3 address : ff500000
[0000.818] GSC4 address : ff400000
[0000.822] GSC5 address : ff300000
[0000.825] GSC MC Settings done
[0000.829] TOS old plaintext Image length 65536
[0000.835] *** Secure OS image signature not verified ***
[0000.840] Loading and Validation of Secure OS Successful
[0000.845] NvTbootPackSdramParams: start.
[0000.850] NvTbootPackSdramParams: done.
[0000.854] Tegraboot started after 171284 us
[0000.858] Basic modules init took 312952 us
[0000.862] Sec Bootdevice Read Time = 194 ms, Read Size = 8464 KB
[0000.868] Sec Bootdevice Write Time = -1940251267 ms, Write Size = 343597383 KB
[0000.875] Next stage binary read took 12282 us
[0000.879] Carveout took 253090 us
[0000.882] CPU initialization took 125376 us
[0000.886] Total time taken by TegraBoot 703700 us
[0000.891] Starting CPU & Halting co-processor
64b[0000.999] RamCode = 0
[0001.014] LPDDR4 Training: Read DT: Number of tables = 10
[0001.019] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0001.024] EMC Training Skipped
[0001.027] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0001.032] EMC Training Skipped
[0001.035] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0001.040] EMC Training Skipped
[0001.043] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0001.048] EMC Training Skipped
[0001.051] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.057] EMC Training Successful
[0001.060] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.066] EMC Training Successful
[0001.069] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.080] EMC Training Successful
[0001.083] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.106] EMC Training Successful
[0001.109] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.131] EMC Training Successful
[0001.134] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.153] EMC Training Successful
[0001.156] Switching to 800000 KHz Success
[0001.163] DT Write: emc-table@40800 succeeded
[0001.169] DT Write: emc-table@68000 succeeded
[0001.175] DT Write: emc-table@102000 succeeded
[0001.182] DT Write: emc-table@204000 succeeded
[0001.188] DT Write: emc-table@408000 succeeded
[0001.194] DT Write: emc-table@665600 succeeded
[0001.201] DT Write: emc-table@800000 succeeded
[0001.207] DT Write: emc-table@1065600 succeeded
[0001.213] DT Write: emc-table@1331200 succeeded
[0001.220] DT Write: emc-table@1600000 succeeded
[0001.224] LPDDR4 Training: Write DT: Number of tables = 10
U-Boot 2015.07-rc2-g78c8468 (Nov 09 2016 - 19:39:36 -0800)
TEGRA210
Model: NVIDIA P2371-2180
DRAM: 4 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x0000000012000000-0x0000000012010000
tegra-pcie: non-prefetchable memory: 0x0000000013000000-0x0000000020000000
tegra-pcie: prefetchable memory: 0x0000000020000000-0x0000000040000000
tegra-pcie: 4x1, 1x1 configuration
tegra-pcie: probing port 0, using 4 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
956 bytes read in 150 ms (5.9 KiB/s)
p2371-2180 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
6902654 bytes read in 325 ms (20.3 MiB/s)
Retrieving file: /boot/Image
20048144 bytes read in 501 ms (38.2 MiB/s)
append: fbcon=map:0 console=tty0n8 androidboot.modem=none androidboot.serialno=t
Retrieving file: /boot/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
423986 bytes read in 456 ms (907.2 KiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000082000000, end 000000008206a831
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.96-tegra (buildbrain@mobile-u64-1072) (gcc ve6
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nt
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff2bf000 - ff2bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: 00000000 - 00000000
[ 0.000000] 2nd Framebuffer: 00000000 - 00000000
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 16 MiB at fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64s
[ 0.000000] DTB Build time: Nov 9 2016 19:40:03
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 1, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2044, Soc Speedo value 1954, Gpu Speed5
[ 0.000000] Tegra21: CPU IDDQ 2136, Soc IDDQ 2336, Gpu IDDQ 2855
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 1 Boof
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_u: boot with h/w control already set
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 163200000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200d
[ 0.000000] tegra dvfs: vdd_core: nominal 1075mV, offset 0uV, step 12500uV, d
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1110mV, offset 710000uV, step 10000d
[ 0.000000] Tegra reset control registration success
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc01fecf000 s20800 r8192 d248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa2
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0n8 androidboot.modet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 2030MB 2048MB = 4078MB total
[ 0.000000] Memory: 4067000k/4067000k available, 108872k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 )
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 )
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 )
[ 0.000000] .init : 0xffffffc00114f000 - 0xffffffc0011ba140 ( 429 )
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc00114e3a4 ( 17209 )
[ 0.000000] .data : 0xffffffc0011ce000 - 0xffffffc00139e7f0 ( 1858 )
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:704 nr_irqs:704 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579s
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled, bootconsole disabled
The TX1 does continue to boot normally, but no more output is logged to minicom. I’m a novice to embedded computing, so most of the above output means nothing to me. However, the fact that the output ends with the line
suggests to me that I’m able to read the bootconsole via J21, but not any of the other consoles. Further running
dmesg | grep tty
on the TX1 gives
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait
[ 1.135764] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 1.136660] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 1.136959] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 1.137336] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
To me this looks only the virtual console (tty0) is enabled. I’m unsure of what the lines that end with “is a Serial Tegra” mean, although I believe ttyTHS1 is the J21 serial console.
Any help with this would be greatly appreciated.
