Enable VI/CSI trace on Jetson Orin Nano using Jetpack 6.2
We are trying to debug a MIPI capture and we require to enable the VI/CSI trace to understand why buffer dequeue is not working, we are using this guide: VI/CSI trace enable
In the Jetson Orin Nano with JP6.2 we are able to use these commands:
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level #File not found!!!
echo > /sys/kernel/debug/tracing/trace
We noticied that /sys/kernel/debug/camrtc/log-level is not present and the /sys/kernel/debug/tracing/trace file provides some information, but not the VI/CSI trace that usually emits a hex value that can be used to understand better why buffer dequeue is not working.
Question: Could you please indicate how to enable the low level VI/CSI trace when using JetPack-6.2 in the Jetson Orin Nano? Is this possible in JP6.2?
Regards.
JP6 need below command to hook the debug node.
sudo modprobe rtcpu_debug   JP6 release needed
