enableCamInfiniteTimeout not working with my custom AR0234 driver
I have developed a Jetson Nano custom Kernel, Device Tree and Driver for AR0234 camera sensor connected through CSI interface.
dpkg-query --show nvidia-l4t-core
nvidia-l4t-core 32.7.6-20241104234540
One of the camera modes if for external HW triggers. I changed sources/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi2_fops.c so it accept infinite timeout. So I need to recompile the kernel.
I want to use with nvarguscamerasrc with gstreamer to be able to use the internal ISP.
The new Kernel, DT and Driver are working fine in streaming modes with v4l2-ctl:
v4l2-ctl --stream-mmap --set-ctrl=sensor_mode=0 --stream-count=100 -d /dev/video0
And gst-launch-1.0:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=0
num-buffers=5 ! ‘video/x-raw(memory:NVMM)’ ! nvvidconv flip-method=0 ! ‘video
/x-raw, format=(string)I420’ ! videoconvert ! ‘video/x-raw, format=(string)RG
B’ ! pngenc ! multifilesink location=“image_%02d.png”
In external trigger mode it also works fine with v4l2-ctl command:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=2
It capture images as they are comming from camera sensor wich is controlled by external TRIGGER signal.
It also works with gst-launch-1.0 as long as it receive frames (triggered by extertal signal) with less time difference than 1500 ms (as expected).
To enable longer (infinite) nvarguscamerasrc timiouts I execute in different console:
$ sudo service nvargus-daemon stop
$ sudo enableCamInfiniteTimeout=1 nvargus-daemon
However when I run (camera in Trigger mode)
I get following trace:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 Failed to create CaptureSession
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.155676014
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Exiting inmediately and not capturing any frame.
Any idea where is the problem?
And how to investigate further or fix it?
Jetson Nano don’t support enableCamInfiniteTimeout.
Hi Shane, thanks for clarification.
What about other SOMs? It is supported in Jetson TX2-NX?
Where can I find documentation for that?
Another question, do you know any workarround?
TX2-NX support it.
Current don’t have any WAR for Nano(t210)
