I’m trying to get the I2S interface to work with a camera driver. Both the I2S and camera work independently, however if I try to setup I2S via jetson-io.py with the camera driver installed, the camera driver stops working. I also know I can use the pinmux table to generate files for the GPIO
I understand that when I enable the I2s via jetson-io.py and reboot the NX, the device tree gets overriden/changed, thus the camera driver is no longer functional. I can create a dtbo and dts file via jetson-io.py . I don’t know where to fit these files in the Linux_For_Tegra Folder. Can someone give me a detailed explaination please?
