I would like to enable the MKEY_BY_NAME firmware parameter, but so far my attempts have been futile. I set the parameter using the following command:
mlxconfig set MKEY_BY_NAME=1
And then reboot to have the change updated. Unfortunately, after that the NIC does not seem to be able to boot. I see the following messages in the kernel log:
[ 160.955995] mlx5_core 0000:01:00.1: wait_fw_init:321:(pid 142): Waiting for FW initialization, timeout abort in 79s
[ 180.959996] mlx5_core 0000:01:00.1: wait_fw_init:321:(pid 142): Waiting for FW initialization, timeout abort in 59s
[ 200.963998] mlx5_core 0000:01:00.1: wait_fw_init:321:(pid 142): Waiting for FW initialization, timeout abort in 39s
[ 220.967428] mlx5_core 0000:01:00.1: wait_fw_init:321:(pid 142): Waiting for FW initialization, timeout abort in 19s
[ 240.947198] mlx5_core 0000:01:00.1: mlx5_function_setup:1279:(pid 142): Firmware over 120000 MS in pre-initializing state, aborting
[ 240.947351] mlx5_core 0000:01:00.1: init_one:1904:(pid 142): mlx5_load_one failed with error code -16
[ 240.948004] mlx5_core: probe of 0000:01:00.1 failed with error -16
Here is short info about the NIC:
Device #1:
Device Type: BlueField
Part Number: MBF1L516A-CSCA_Ax
Description: BlueField™ SmartNIC 100GbE; Dual Port QSFP28; PCIe Gen4.0 x16; BlueField™ G-Series 16 cores; Crypto enabled; 16GB on-board DDR; FHHL; Single Slot; Tall Bracket
PSID: MT_0000000247
PCI Device Name: 0000:01:00.0
Base GUID: 1c34da030071d8b2
Base MAC: 1c34da71d8b2
Versions: Current Available
FW 18.31.2006 N/A
NVMe 20.1.0005 N/A
PXE 3.6.0404 N/A
UEFI 14.24.0015 N/A
Status: No matching image found
Could you please help me to figure out how to enable the desired configuration option?
