Finally I got something for the PPS injection in the AGX Xavier
For those with the same issues, here is what I did :
Activate PPS support, as mentioned in the thread, on the kernel in the file .config
# PPS support CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # PPS clients support CONFIG_PPS_CLIENT_KTIMER=y CONFIG_PPS_CLIENT_LDISC=y CONFIG_PPS_CLIENT_GPIO=y # PPS generators support # CONFIG_NVPPS is not set
Then edit the file
tegra194-soc-base.dtsi
innvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc
by addingpps: pps_gpio { compatible = "pps-gpio"; gpios = <&tegra_main_gpio 206 1>; assert-falling-edge; status = "okay"; };
Then recompile the kernel and flash it, check pps0 and pps1 with pps-tools
Now, I try to configure ntp and ptp with this configuration.
For now, my configuration for ntp is :
server 127.127.20.0 mode 24 minpoll 3 burst iburst prefer
fudge 127.127.20.0 stratum 1 flag1 1 flag2 0 flag3 1 flag4 0 time1 0.0 time2 0.0 refid GPS0
server 127.127.28.0 minpoll 4
fudge 127.127.28.0 time1 0.0 refid NMEA
server 127.127.28.1 minpoll 4 prefer
fudge 127.127.28.1 refid PPS
ls -la /dev/gps*
lrwxrwxrwx 1 root root 12 déc. 18 15:10 /dev/gps0 -> /dev/ttyTHS0
lrwxrwxrwx 1 root root 9 déc. 18 15:10 /dev/gpspps0 -> /dev/pps1
nptime seems to be disagree to my setup
$ntptime
ntp_gettime() returns code 0 (OK)
time e3874a4a.9fb22000 Fri, Dec 18 2020 16:33:30.623, (.623812),
maximum error 1205016 us, estimated error 16 us, TAI offset 0
ntp_adjtime() returns code 0 (OK)
modes 0x0 (),
offset 0.000 us, frequency 0.000 ppm, interval 1 s,
status 0x1 (PLL),
time constant 7, precision 1.000 us, tolerance 500 ppm,
Any advises ?
