In Nvidia Nano B01 development kit board bearing board version 180-13449-DAAF-B01
Can i use SDIO pins on M.2 connector
SDIO_RESET pin 23 M.2 Key E
SDIO_WAKE pin 21 M.2 Key E
SDIO_DATA3 pin 19 M.2 Key E
SDIO_DATA2 pin 17 M.2 Key E
SDIO_DATA1 pin 15 M.2 Key E
SDIO_DATA0 pin 13 M.2 Key E
SDIO_CMD pin 11 M.2 Key E
SDIO_CLK pin 9 M.2 Key E
Wayne,
Request you to clarify the above queries. Thanks.
Wayne,
I have one last clarification if In Nvidia Nano B01 development kit board bearing board version 180-13449-DAAF-B01
PLease clarify the same
What do you want to do here? Rework the board?
No i dont intend to rework the board. Since i am unable to use J501 Micro SD slot for sdmmc, can i use the these SDIO pins on the M.2 connector…
If above pins are not useable then will go ahead with custom nvidia nano board . For this i required confirmation.
Please clarify the same. Thanks
Are you trying to use a M.2 device that is based on SDIO? For example, a SDIO wifi card?
If not, then how do you expect to connect those pin on m.2 connector without rework the board?
Wayne,
If SDIO on M.2 is useable, then I plan to connect CYW54591 wifi card to M.2 slot on Nvidia Nano eval kit.
No, this is not supported on devkit as we didn’t test SDIO wifi card on that m.2 slot.
Thanks Wayne,
can we add any patch to make this SDIO work?
sorry wayne for asking multiple times/ questions. Can we enable SDIO on M.2 using software" ?
No, that is not validated. So we would say it is not supported.
