Enabling Uart And Ethernet Interface on Boot
I am using NVIDIA Xavier hardware and using doflash for flashing the image.
I am using meta-tegra for the build.
I am not able to enable the uart serial terminal and Ethernet interface on boot. To enable the Ethernet interface i need to give command to make the interface up.
I want this Ethernet interface to get enabled as soon as image boots up.
I request you all to please suggest me how I can do it.
Regards,
Hariom
I believe you should post this question to the Xavier group: Jetson Xavier NX - NVIDIA Developer Forums
This current group is for SONIC, and isn’t related to Jetson Xavier. Sorry for the confusion.
I can only say that none of the tool and build you are using is directly from our official software.
If you have problem with meta-tegra, please ask your question over GitHub - OE4T/meta-tegra: BSP layer for NVIDIA Jetson platforms, based on L4T.
This is not maintained by us.
