Encoded RTSP streaming examples
Dear Gstreamer experts,
I am not familiar with Gstreamer as well as H264/H265 accelerated encoding by Jetson hardware. Could you help to share some example of working pipeline to stream the video from the Sony FCB-EV9500M to remote laptop/desktop, please ?
Below is the info of the video devices in the running system (based on Jetpack-5.0.2) :
$ v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
	/dev/media0
vi-output, ev9500m 8-0010 (platform:tegra-capture-vi:0):
	/dev/video0
vi-output, adv7280 8-0020 (platform:tegra-capture-vi:4):
	/dev/video1
Thanks in advance
Please check the examples in Jetson Nano FAQ
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
Hi @DaneLLL,
Thank you for your instruction. I was able to stream the test pattern with :
$ ./test-launch "videotestsrc is-live=1 ! nvvidconv ! nvv4l2h264enc ! h264parse ! rtph264pay name=pay0 pt=96"
on the Jetson NX side and visualize with VLC software (rtsp://<SERVER_IP_ADDRESS>:8554/test ).
However, I tried to do the same thing with my CSI camera /dev/video0 as below:
	/dev/media0
	/dev/video0
$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
	[0]: 'UYVY' (UYVY 4:2:2)
		Size: Discrete 1920x1080
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.017s (60.000 fps)
	[1]: 'NV16' (Y/CbCr 4:2:2)
	[2]: 'UYVY' (UYVY 4:2:2)
with below command for Jetson NX side :
./test-launch "nvarguscamerasrc ! video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=NV12 ! nvvidconv ! nvv4l2h265enc ! h265parse ! rtph265pay name=pay0 pt=96"
stream ready at rtsp://127.0.0.1:8554/test
When I launch the VLC with rtsp
://<SERVER_IP_ADDRESS>:8554/test, the following error:
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
GST_ARGUS: Cleaning up
Could you help to troubleshoot, please?
Khang
Please use v4l2src(or nvv4l2camerasrc) for UYVY format. You may check Jetson Nano FAQ
Q: I have a USB camera. How can I launch it on Jetson Nano?
Hi @DaneLLL ,
For Jetson Xavier NX side, I tried
./test-launch "nvv4l2camerasrc device=/dev/video0 ! video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=UYVY ! nvvidconv ! nvv4l2h265enc ! h265parse ! rtph265pay name=pay0 pt=96"
NVMEDIA: H265 : Profile : 1
NVMEDIA: Need to set EMC bandwidth : 141000
NVMEDIA_ENC: bBlitMode is set to TRUE
But on client side, VLC could not visualize even-though it reported no error.
Best,
Khang
Please tryv4l2src. See if the plugin works.
I got following error when starting VLC :
$ ./test-launch "v4l2src device=/dev/video0 ! video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1,format=UYVY ! nvvidconv ! nvv4l2h265enc ! h265parse ! rtph265pay name=pay0 pt=96"
Resolution: 1920 x 1080 ; Framerate = 59.999999; Analog Gain Range Min 1.000000, Max 16.000000, Exposure Range Min 34000, Max 550385000
DEFAULT no IOCTL called
Not Implemented
Try removing (memory:NVMM). v4l2src uses system memory.
Hi @Honey_Patouceul ,
Your solution works for me. Thank you very much!
Just last question : I cannot use nvarguscamerasrc, can I ?
No. The nvarguscamerasrc plugin is for Bayer sensors using ISP engine. It supports RAW formats such as BG10.
Hi @DaneLLL ,
Thanks very much. We are going to use many RAW Bayer sensors and this information is really useful.
Best Regards,
Khang
