Encoding limit for 4k stream
Hi
I need to encode an rtsp stream from an unknown number of 4k IP cameras.
the specs relate to only to two cases of 2 or 4 streams @60/30 fps.
is it possible to increase the number of streams more than that and reduce the fps or is there another technical issue preventing it?
best regards!
Yes, it is possible. You can increase number of streams and the frame rate will be decreased. Please try and find the acceptable number of streams and frame rate for the use-case.
