Software Version
DRIVE OS 6.0.4 SDK
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.2.10884
Host Machine Version
describes a bug in the camera driver causing it to stop receiving images after we use all of the buffers allocated for the INvSIPLCamera instance one time. In other words, the buffers that we allocate for SIPL’s ISP pipelines are never re-used / properly marked as re-usable.
Below is a high-level outline of how our driver is structured:
Initialization of camera instance & memory
Load platform configuration
Create INvSIPLCamera instance
Set platform config
Set pipeline config
Init()
Allocate memory for the ISP pipelines (currently we allocate a queue of 10 images for each ISP pipeline that is enabled in the pipeline configuration. Our pipeline configuration is enabling outputs from ICP and ISP0 only)
The buffers are allocated via NvSciBuf
Each buffer is of type NvSciBufType_Image
Each buffer has NvSciBufAccessPerm_ReadWrite
ISP0 buffers are also assigned NvSciBufGeneralAttrKey_NeedCpuAccess = true and NvSciBufGeneralAttrKey_EnableCpuCache = true
1. ICP buffers are not assigned these permissions. It’s my understanding from `nvsipl_camera` that ICP does not need these attributes?
Buffers also have image attributes that were received from INvSIPLCamera::GetImageAttributes()
Buffers are registered with camera instance via INvSIPLCamera::RegisterImages()
NITO file from Quanta is loaded & registered with camera instance via INvSIPLCamera::RegisterAutoControlPlugin()
Camera instance is started via INvSIPLCamera::Start()
Summary questions
Other than marking a buffer as finished via INvSIPLClient::INvSIPLBuffer::Release(), what else needs to be done so that SIPL recognizes that a buffer can be reused?
Has there been any thought to include a method to access the reference count of an INvSIPLClient::INvSIPLBuffer? There are methods to AddRef() and Release(), but no way to see what the value of the current ref count is.
Are we supposed to be accessing the images from the ICP INvSIPLFrameCompletionQueue? Do we need to Get() them and mark them as released? Is it okay to just access the ISP0 queue?
If a buffer is never accessed via Get() its reference count would be 0 and it would be available for reuse by SIPL, correct?
If ISP1 and ISP2 outputs are disabled, we don’t need to do anything else with them, right?
Do we need to integrate NvSciSync in order to access a buffer and write it to a ROS message? I assume if we were doing inter-process communication or sharing buffers between threads to do other processing we’d need NvSciSync to help. Is it necessary for just reading the raw data in the same thread that’s calling INvSIPLFrameCompletionQueue::Get()? What purpose is it serving in that case?
