i’m trying to use secure boot + encrypted filesystem on my board.
i started with using the latest 32.6.1 version, and burned the fuses, created the eks.img and flashed the board using:
sudo ./odmfuse.sh -p -i 0x19 -k ./rsa_priv.pem -S ./sbk.txt --KEK2 ./kek2_key.txt jetson-xavier-nx-devkit-emmc
python3 gen_ekb.py -kek2_key kek2_key.txt -fv fv_for_ekb_ek.txt -in_sym_key user_key_for_ekb.txt -in_sym_key2 disk_enc_key.txt -out eks.img
sudo ROOTFS_ENC=1 ./flash.sh -u ./rsa_priv.pem -v ./sbk.txt -i ./disk_enc_key.txt --user_key ./user_key_for_flash.txt jetson-xavier-nx-devkit-emmc mmcblk0p1
everything worked and i was able to boot and run everything.
I then needed to revert to the 32.5.1 version and tried to do the same process on the same board.
at first the board didn’t boot, I applied the 0001-lib-tegrabl_auth-fix-a-bug-in-decrypting-buffer.patch patch to cboot, compiled and flashed again and the board did boot but i got the following error:
and after I press ok i got on boot:
[ TIME ] Timed out waiting for device .dev.mapper/crypt_UDA.
[DEPEND] Dependency failed for File System Check on /dev/mapper/crypt_UDA.
I tried flashing again without the 'ROOTFS_ENC=1 ’ and everything looked ok, so the problem is with the encrypted filesystem.
the partition config i used is basically ‘flash_l4t_t194_spi_emmc_p3668_enc_rootfs_ab.xml’ with the following changes:
<partition name="APP" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 104857600 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<align_boundary> 4096 </align_boundary>
<unique_guid> APPUUID </unique_guid>
<filename> system_boot.img </filename>
<description> **Required.** Contains the boot partition. This partition must be defined
after `primary_GPT` so that it can be accessed as the fixed known special device
`/dev/mmcblk0p1`. </description>
</partition>
<partition name="APP_ENC" type="data" encrypted="true">
<size> APP_ENC_SIZE </size>
<unique_guid> APP_ENC_UUID </unique_guid>
<filename> system_root_encrypted.img </filename>
<description> **Required.** Contains the encrypted root partition("/"). </description>
<partition name="UDA" type="data" encrypted="true">
<size> 167772160 </size>
<allocation_attribute> 0x808 </allocation_attribute>
<filename> system_uda_encrypted.img </filename>
<description> **Required.** Automatically takes all remaining space on the device except that
occupied by the `secondary_gpt` partition. Allocation attribute must be set to 0x808.
May be mounted and used to store user data. </description>
</partition>
do I need to do anything else? are there any additional steps needed for version 32.5.1?
any help will be greatly appreciated.
