Energy consumption for inference
Hello All,
I want to measure the energy consumed while doing inference on Xavier’s GPU.
I have read Jetson AGX Xavier Thermal Design Guide, so there are sysfs nodes which report voltage and current plus an averaged power over 512 sample.
Now in that doc:
It is recommended to set the sample interval to 1 second or longer.
Given that the inference time is very short, say 30ms, I can’t even get a few power measurements to have an averaged power.
Then the question is, if you wanted to see the energy efficiency of a given model, how would you go for it?
Thanks,
Hi, is it possible to run this inference repeatedly? If yes, there should be enough sampled values for average power calculating with 1 second interval.
