• Hardware Platform (Jetson)
• DeepStream Version 6.1.1
• JetPack Version 5.02
• TensorRT Version
• Issue Type( question)
• How to reproduce the issue ? (Launching on Jetson with jetpack 5.02 a docker container using a object detector with resnet 10 4 class. In the logs of the jetson docker start an error is shown. )
• Requirement details( I have created the docker container on ubuntu 20.04 with deepstream 6.2 and graph composer 2.5. The deepstream app runs after start, but I cannot verify if that object detector is wrong initiated. Please give valuable help. thanks.)
stefan@xavier:~$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/argus_socket:/tmp/argus_socket pizzabox.homebase.local:5050/stefan/deepstream_rtsp_x4_rtsp_out_jetson:test
2023-03-07 08:02:22.489 INFO gxf/gxe/gxe.cpp@180: Creating context
2023-03-07 08:02:22.680 INFO gxf/gxe/gxe.cpp@105: Loading app: ‘deepstream_rtsp_x4_rtsp_out.yaml’
2023-03-07 08:02:22.680 INFO gxf/std/yaml_file_loader.cpp@129: Loading GXF entities from YAML file ‘deepstream_rtsp_x4_rtsp_out.yaml’…
2023-03-07 08:02:22.702 INFO gxf/gxe/gxe.cpp@105: Loading app: ‘parameters_rtsp_x4_rtsp_out.yaml’
2023-03-07 08:02:22.702 INFO gxf/std/yaml_file_loader.cpp@129: Loading GXF entities from YAML file ‘parameters_rtsp_x4_rtsp_out.yaml’…
2023-03-07 08:02:22.708 INFO gxf/gxe/gxe.cpp@249: Initializing…(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:22.948: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:22.999: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:23.144: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:23.148: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:23.300: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:23.971: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 08:02:24.175: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
2023-03-07 08:02:25.167 INFO extensions/nvdsbase/nvds_scheduler.cpp@270: This program is linked against GStreamer 1.16.32023-03-07 08:02:25.177 INFO extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin single_source_input
2023-03-07 08:02:25.177 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux streammux
2023-03-07 08:02:25.178 INFO extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin object_detector
2023-03-07 08:02:25.178 INFO extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin onscreen_display
2023-03-07 08:02:25.179 INFO extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin Single Source Input7
2023-03-07 08:02:25.180 INFO extensions/nvdsvisualization/nvtilerbin.hpp@37: initialize: nvtilerbin Video Tiler11
2023-03-07 08:02:25.180 INFO extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@23: initialize: nvrtspoutsinkbin nv_ds_rtsp_out21
2023-03-07 08:02:25.181 INFO extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin Single Source Input0
2023-03-07 08:02:25.181 INFO extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin Single Source Input3
2023-03-07 08:02:25.181 INFO extensions/nvdstracker/nvtrackerbin.hpp@23: initialize: nvtrackerbin Object Tracker6
2023-03-07 08:02:25.182 INFO extensions/nvdsanalytics/nvdsanalytics.hpp@23: initialize: nvdsanalytics Object Analytics11
2023-03-07 08:02:25.182 INFO gxf/gxe/gxe.cpp@256: Running…
2023-03-07 08:02:25.182 INFO extensions/nvdsbase/nvds_scheduler.cpp@121: Scheduling 11 elements and 1 components
2023-03-07 08:02:25.182 INFO extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin single_source_input2023-03-07 08:02:25.436 INFO extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin single_source_input
2023-03-07 08:02:25.436 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux streammux
2023-03-07 08:02:25.439 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux streammux
2023-03-07 08:02:25.440 INFO extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin object_detector
2023-03-07 08:02:25.446 INFO extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin object_detector
2023-03-07 08:02:25.450 INFO extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin onscreen_display
2023-03-07 08:02:25.458 INFO extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin onscreen_display
2023-03-07 08:02:25.459 INFO extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin Single Source Input7
2023-03-07 08:02:25.459 INFO extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin Single Source Input7
2023-03-07 08:02:25.459 INFO extensions/nvdsvisualization/nvtilerbin.hpp@45: create_element: nvtilerbin Video Tiler11
2023-03-07 08:02:25.463 INFO extensions/nvdsvisualization/nvtilerbin.hpp@69: bin_add: nvtilerbin Video Tiler11
2023-03-07 08:02:25.463 INFO extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@31: create_element: nvrtspoutsinkbin nv_ds_rtsp_out21
2023-03-07 08:02:25.463 INFO extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@55: bin_add: nvrtspoutsinkbin nv_ds_rtsp_out21
2023-03-07 08:02:25.464 INFO extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin Single Source Input0
2023-03-07 08:02:25.464 INFO extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin Single Source Input0
2023-03-07 08:02:25.464 INFO extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin Single Source Input3
2023-03-07 08:02:25.464 INFO extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin Single Source Input3
2023-03-07 08:02:25.465 INFO extensions/nvdstracker/nvtrackerbin.hpp@31: create_element: nvtrackerbin Object Tracker6
2023-03-07 08:02:25.468 INFO extensions/nvdstracker/nvtrackerbin.hpp@55: bin_add: nvtrackerbin Object Tracker6
2023-03-07 08:02:25.468 INFO extensions/nvdsanalytics/nvdsanalytics.hpp@31: create_element: nvdsanalytics Object Analytics11
2023-03-07 08:02:25.469 INFO extensions/nvdsanalytics/nvdsanalytics.hpp@55: bin_add: nvdsanalytics Object Analytics11
*** NvDsRtspOut/nv_ds_rtsp_out21: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
WARNING: Deserialize engine failed because file path: primary.resnet10.caffemodel_b4_gpu0_int8.engine open error
0:00:06.433980717 1 0xffff5c018180 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :primary.resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:06.508653180 1 0xffff5c018180 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :primary.resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:06.509348225 1 0xffff5c018180 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
