• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 4070
• DeepStream Version 7.0
• TensorRT Version 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) 560.35.03
• Issue Type( questions)
The following is the expected IO configs of the engines to work on follow-up logics.
deepstream-1 | INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 4
deepstream-1 | 0 INPUT kFLOAT input 3x640x640
deepstream-1 | 1 OUTPUT kFLOAT boxes 25200x4
deepstream-1 | 2 OUTPUT kFLOAT scores 25200x1
deepstream-1 | 3 OUTPUT kFLOAT classes 25200x1
But for a new GPU based generated engine contains the following IO configs and we were unable to get the detections out.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 5
deepstream-1 | 0 INPUT kFLOAT x 3x640x640
deepstream-1 | 1 OUTPUT kFLOAT onnx::Sigmoid_1226 3x80x80x10
deepstream-1 | 2 OUTPUT kFLOAT onnx::Sigmoid_1590 3x40x40x10
deepstream-1 | 3 OUTPUT kFLOAT onnx::Sigmoid_1953 3x20x20x10
deepstream-1 | 4 OUTPUT kFLOAT 2267 25200x10
How to solve this?
yuweiw
October 31, 2024, 5:28am
3
Are you saying that you are using the same model, the same config file, the same pipeline to generate different engine IO on different Gpus?
Yeah, I have generated an engine file from an onnx file in another GPU with the same configs and the same deepstream pipeline
yuweiw
October 31, 2024, 8:01am
5
The engine files generated by the models cannot be shared between different gpus. When you change the GPU, you should regenerate the engine file.
Yeah, I have regenerated the engine in my new GPU device and there is this output logs.
And in the previous GPU, I got the logs as follows,
In the newly generated engine I am able to run the pipeline for the detection but I do not get the predictions from it.
yuweiw
November 5, 2024, 11:08am
8
Could you attach your model and config file to us? Also could you attach the specific type of the two GPUs?
system
Closed
December 19, 2024, 2:40am
10
