**• Hardware Platform (GPU) RTX 3060
**• DeepStream Version 6.0
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA11.7
• Issue Type (questions)
您好,我在Deepstream上使用YoloV7的.weight與.pt檔,透過config檔案設定可以讓程式將他們轉換成engine檔,那有辦法在這轉換過程中對engine進行加密的動作嗎?還是只能在生成engine檔案後再對檔案進行加密?
Translated from zh-Hant by Microsoft
Hello, I use YoloV7’s .weight and .pt files on Deepstream, and I can convert them into engine files through config file settings, so is there a way to encrypt the engine during this conversion process? Or can you only encrypt the engine file after it has been generated?
