Make it easier to do triage and supply log output for posts or problem reports.
which logs are you talking about? System logs, app logs, etc?
Logs currently shown in the log view, various service, build, and operation logs.
Haven’t even thought about the logs that exist that are not shown in the log view
is it that you only want part of the logs, or rather the last bit of the logs that are relevant?
I want it to be easy to copy the logs and send them somewhere like here or as a problem report.
Lets say I’m having trouble loading the model and I try a couple different times with different settings. Those logs might be co-mingled in the same log file. I’d like to clear the log before I try anything. So that the log file only contains my last attempt.
Sometimes there are a bunch of logs before I take an action. I’d like to be able to clear that out.
Sometimes I want to copy a fragment of the logs to blog article. Currently it is kind of painful.
