The device enter recovery boot when we reset the device.
why did it happen? we just reset.
Is this your custom board?
yes ,it is our customer found, we need the reason.
What you saw is the fastboot mode. If you read the log, it will tell you why it enters the fastboot mode.
[0008.618] Power button long press detected
[0008.622] Entering fastboot mode...
[0008.625] starting fastboot mode
[0008.630] fastboot cmd_init done.
[0008.633] platform does not support off-mode-charge
[0008.638] usbdcd_init Initialize USBF driver
[0008.642] usbdcd_phy_open oscfreq = 5
[0008.651] usbdcd_start Start the initialized controller
[0008.658] get_fast-- suspend --
b[0008.661] oot_instructions: Error -2 finding instructions in /chosen
[0008.691] Key Code 8 not handled
[0008.894] Key Code 8 not handled
Please check if your hardware design triggers power button here.
Looks like you already asked the same question last year.
There is one post which has a solution over the hardware. Maybe you can take a look.
we found another problem, it didn’t enter fastboot, but cann’t boot.
help to analyze it, thank you!
not_boot.log (26.1 KB)
Is this still an issue to support? Any result can be shared? Thanks
