**Hardware Platform: DRIVE AGX Xavier™ Developer Kit
**Software Version: DRIVE Software 10
**Host Machine Version: native Ubuntu 18.04
**SDK Manager Version:1.1.0.6343
Once I connected ENTRON F008A1200BM0A 8 MP camera and tried running in the target using the ./sample_camera_gmsl - It seems like there is a problem and throws this error:
[21-09-2019 01:05:31] Initialize DriveWorks VisualizationSDK v2.2.3136 [21-09-2019 01:05:31] Initialize DriveWorksGL SDK v2.2.3136 [21-09-2019 01:05:31] SensorFactory::createSensor() -> camera.gmsl, output-format=yuv,fifo-size=3,isp-mode=yuv420-uint8,camera-type=ar0231-rccb-bae-sf3324,camera-group=a,slave=0 [21-09-2019 01:05:31] CameraGMSL: Couldn't set CameraGMSL setup thread sched params! [21-09-2019 01:05:31] CameraGMSL: Create NvMediaIPPManager [21-09-2019 01:05:31] CameraGMSL: required FPS = 30, resolution = 1920x1208 nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP Max96712 Rev 2 detected! nvmedia: ERROR: WriteArray: MAX96712: error: wri2c 0x0C 0x08 nvmedia: ERROR: SetupConfigLink: Failed to enable packet based control channel nvmedia: ERROR: Init: Failed to setup config link [21-09-2019 01:05:42] Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraGMSL: cannot connect to camera terminate called after throwing an instance of 'std::runtime_error' what(): [2019-09-21 01:05:42] DW Error DW_SAL_CANNOT_CREATE_SENSOR executing DW function: dwSAL_createSensor(&m_camera, params, m_sal) at /usr/local/driveworks-2.2/samples/src/sensors/camera/camera_gmsl/main.cpp:174 Aborted (core dumped)
But the sample works fine for the Sekonix camera that comes with the kit. Any workaround to make it detect ? Do this target support entron cameras?
