Been working on a numerical solver. When dealing with values close to machine epsilon (around 1.19e-7 for float32), noticing some inconsistency in results between CPU and GPU runs.
Just to clarify, epsilon and latin open E are 2 different symbols, though they look exactly same. Latin open e is also called reversed 3. But here, I’m talking about the epsilon.
Is there a way to handle comparisons near epsilon in CUDA kernel? Been using FLT_EPSILON from <float.h> but wondering if theres a pattern other use. (when dealing with denormals or flush-to-zero mode)
TIA!
