Equivalent to HEVC V4L2_CID_MPEG_VIDEOENC_INSERT_SPS_PPS_AT_IDR for AV1?
The above control forces the encoder to insert SPS/PPS etc with every IDR.
However, I can’t see the equivalent for AV1 to insert a sequence header OBU with every IDR. I thought maybe the above control would work for AV1, but I can confirm that it does not.
The desktop Video SDK has config_hevc.repeatSPSPPS for HEVC and config_av1.repeatSeqHdr for AV1.
Can we have the same for Jetson?
On current releases there is no equivalent property for AV1. We will check it and add into future release.
No worries, thanks for checking.
