Is there a way to make a Jetson HEVC output bitstream add filler bytes to maintain CBR?
From the Video SDK description:
uint32_t enableFillerDataInsertion :1; /**< [in]: Set to 1 to enable insertion of filler data in the bitstream.
This flag will take effect only when CBR rate control mode is in use and both
NV_ENC_INITIALIZE_PARAMS::frameRateNum and
NV_ENC_INITIALIZE_PARAMS::frameRateDen are set to non-zero
values. Setting this field when
NV_ENC_INITIALIZE_PARAMS::enableOutputInVidmem is also set
is currently not supported and will make ::NvEncInitializeEncoder()
return an error. */
