As part of testing our factory toolchain, it’s very useful to have a fully “blank” Xavier NX - since when we get them, they don’t boot at all until the flashing cycle has run - but for testing new parts of our workflow, it would be really useful to be able to “factory reset” a Xavier NX.
What’s the correct way to do this? I found an old post that referred to tegradevflash_v2 but did not actually specify how to run this.
To be clear: what I’m hoping to accomplish is to erase everything on the Xavier NX so that it doesn’t boot and has no data - just like we get them when new. Also, if I then re-flash, I’d like the device to boot again. (I’m not trying to create bricks here :) )
currently, you can try the following method for erasing individual partitions with tegraflash.py.
Put the device into recovery
Run the command
sudo ./flash.sh --no-flash --sign --no-systemimg <board> mmcblk0p1
Extract the command from “bootloader/flashcmd.txt” and replace the “sign” with “erase <partition name>” after –cmd
Change to “bootloader” directory and run the command obtained in step 3 with “sudo”
I just confirmed it’s working by erasing the APP partition on my AGX Orin.
Erasing the whole device should be done with tegradevflash_v2, but the workflow is more complicated and integrated into the flashing process, so we may need sometime to figure out how to run it individually.
OK, I was able to erase the BCT partition - this looks like enough for me for now, as it makes the device completely unresponsive until re-flashing - which was my goal.
some updates here:
In tegradevflash_v2, the process of erasing the whole device is followed by writing every partitions back, so you either erase a single partition, or erase them all and write them all back, and you cannot just erase the device and leave it as is.
