Eroneous Distance Transform using PBA
PBA Distance Transform using NPP returns non-exact EDT.
I followed the examples at https://github.com/NVIDIA/CUDALibrarySamples/tree/master/NPP/distanceTransform
In these examples, I set the first row a sites.
// nppiDistanceTransformPBA_8u32f_C1R_Ctx
[0]: 0 0 0 0 0 0 0 0 0 0
[1]: 1 1 1 1 1 1 1 1 1 1
[2]: 1 1 1 1 1 1 1 1 1 1
[3]: 3 3 3 3 3 3 3 3 3 3
[4]: 3 3 3 3 3 3 3 3 3 3
[5]: 4 4 4 4 4 4 4 4 4 4
[6]: 5 5 5 5 5 5 5 5 5 5
[7]: 6 6 6 6 6 6 6 6 6 6
[8]: 7 7 7 7 7 7 7 7 7 7
[9]: 8 8 8 8 8 8 8 8 8 8
[10]: 9 9 9 9 9 9 9 9 9 9
// nppiDistanceTransformAbsPBA_8u16u_C1R_Ctx
[4]: 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5
[5]: 4.5 4.5 4.5 4.5 4.5 4.5 4.5 4.5 4.5 4.5
[6]: 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5
[7]: 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5 6.5
[8]: 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5
[9]: 8.5 8.5 8.5 8.5 8.5 8.5 8.5 8.5 8.5 8.5
[10]: 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5
I have filed an internal bug (4832970) to have the issue looked at. I won’t be able to make any further comments until there is progress on the bug. I don’t have a schedule for progress on the bug. If there is no update from me here, it means that there is no development in the bug yet to report.
I’d be happy to help!
I’m seeing the exact same issue on one system, but not on another. I am using nppiDistanceTransformPBA_8u32f_C1R_Ctx.
System with issue:
RTX 4070
CUDA/NPP version: 11.8
System without issue:
Jetson Orin Nano 4GB
CUDA/NPP version: 11.4
The nature of the issue is exactly as demonstrated in the parent post. Locations which should have distances of 2 are reported to have distances of 1. This appears to right itself at distance 3. Then at positions which should have distance 4, we see distance 3.5. Then the rate of the distance increments correctly, though the values themselves are incorrect. (3.5, 4.5, 5.5 where it should be 4, 5, 6)
I replied here on github but I wanted to copy and paste my response. As I’m unsure where things are best tracked.
We originally did not encounter this issue on Jetson Orin Nano 4GB. However, since upgrading to Jetpack 6 with Cuda NPP version 12.3.1 we seem to be observing this same problem now on Jetson. Here’s a sample program
#include <stdio.h>
#include <stdlib.h>
#include "cuda_runtime.h"
#include "nppdefs.h"
#include "nppcore.h"
#include "nppi_filtering_functions.h"
#include "npps_initialization.h"
#define min(x, y) (((x) < (y)) ? (x) : (y))
#define nImageWidth 64
#define nImageHeight 64
int test_npp()
    NppStreamContext nppStreamCtx;
    nppStreamCtx.hStream = 0;
    cudaGetDevice(&nppStreamCtx.nCudaDeviceId);
    cudaDeviceGetAttribute(&nppStreamCtx.nCudaDevAttrComputeCapabilityMajor,
                           cudaDevAttrComputeCapabilityMajor,
    cudaDeviceGetAttribute(&nppStreamCtx.nCudaDevAttrComputeCapabilityMinor,
                           cudaDevAttrComputeCapabilityMinor,
    cudaStreamGetFlags(nppStreamCtx.hStream, &nppStreamCtx.nStreamFlags);
    struct cudaDeviceProp oDeviceProperties;
    cudaGetDeviceProperties(&oDeviceProperties, nppStreamCtx.nCudaDeviceId);
    nppStreamCtx.nMultiProcessorCount = oDeviceProperties.multiProcessorCount;
    nppStreamCtx.nMaxThreadsPerMultiProcessor = oDeviceProperties.maxThreadsPerMultiProcessor;
    nppStreamCtx.nMaxThreadsPerBlock = oDeviceProperties.maxThreadsPerBlock;
    nppStreamCtx.nSharedMemPerBlock = oDeviceProperties.sharedMemPerBlock;
    NppiSize oImageSizeROI = {nImageWidth, nImageHeight};
    Npp8u hostInputBuffer[nImageHeight * nImageWidth] = {0};
    for (int i = 0; i < nImageWidth; i++) {
      // Fill first row with 1s
      hostInputBuffer[i] = 1;
    printf("Input array (%dx%d):\n", nImageWidth, nImageHeight);
    if (nImageWidth != 8) {
          printf("Truncating printed width to %d\n", 8);
    for (int y = 0; y < nImageHeight; y++) {
        for (int x = 0; x < min(8, nImageWidth); x++) {
            printf("%d ", hostInputBuffer[y * nImageWidth + x]);
        printf("\n");
    Npp8u *pInputImage_Device = 0;
    Npp32f *pOutputImage_Device = 0;
    Npp8u *pScratchBuffer = 0;
    Npp32f *hostOutputBuffer = 0;
    size_t nScratchBufferSize;
    nppiDistanceTransformPBAGetBufferSize(oImageSizeROI, &nScratchBufferSize);
    printf("Scratch buffer size: %zu bytes\n", nScratchBufferSize);
    cudaMalloc((void **)&pScratchBuffer, nScratchBufferSize);
    cudaMalloc((void **)&pInputImage_Device, oImageSizeROI.width * sizeof(Npp8u) * oImageSizeROI.height);
    cudaMalloc((void **)&pOutputImage_Device, oImageSizeROI.width * sizeof(Npp32f) * oImageSizeROI.height);
    hostOutputBuffer = (Npp32f *)malloc(oImageSizeROI.width * sizeof(Npp32f) * oImageSizeROI.height);
    if (pScratchBuffer == 0 || pInputImage_Device == 0 || pOutputImage_Device == 0 || hostOutputBuffer == 0)
        printf("Memory allocation failed\n");
        if (pScratchBuffer)
            cudaFree(pScratchBuffer);
        if (pInputImage_Device)
            cudaFree(pInputImage_Device);
        if (pOutputImage_Device)
            cudaFree(pOutputImage_Device);
        if (hostOutputBuffer)
            free(hostOutputBuffer);
        return -1;
    cudaMemcpy(pInputImage_Device, hostInputBuffer,
               oImageSizeROI.width * oImageSizeROI.height * sizeof(Npp8u),
               cudaMemcpyHostToDevice);
    Npp8u nMinSiteValue = 1;
    Npp8u nMaxSiteValue = 1;
    printf("Running distance transform...\n");
    NppStatus status = nppiDistanceTransformPBA_8u32f_C1R_Ctx(
        pInputImage_Device, oImageSizeROI.width * sizeof(Npp8u),
        nMinSiteValue, nMaxSiteValue,
        0, 0,
        0, 0,
        0, 0,
        pOutputImage_Device, oImageSizeROI.width * sizeof(Npp32f),
        oImageSizeROI, pScratchBuffer, nppStreamCtx);
    if (status != NPP_SUCCESS)
        printf("Distance transform failed with error: %d\n", status);
    else
        printf("Distance transform completed successfully!\n");
        cudaMemcpy(hostOutputBuffer, pOutputImage_Device,
                   oImageSizeROI.width * sizeof(Npp32f) * oImageSizeROI.height,
                   cudaMemcpyDeviceToHost);
        if (nImageHeight != 8) {
                printf("%.1f ", hostOutputBuffer[y * nImageWidth + x]);
            printf("\n");
    cudaDeviceSynchronize();
    printf("Done!\n");
    return 0;
int main() {
  void *x = 0;
  cudaMallocHost((void **)&x, 8);
  if (x != 0) {
    cudaFreeHost(x);
    x = 0;
  NppLibraryVersion * version = nppGetLibVersion();
  printf("%d %d %d\n", version->major, version->minor, version->build);
  test_npp();
as well as its output on jetson
12 3 1
Input array (64x64):
Truncating printed width to 8
1 1 1 1 1 1 1 1
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
Scratch buffer size: 98840 bytes
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0
3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0
10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5
11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5
12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5
13.5 13.5 13.5 13.5 13.5 13.5 13.5 13.5
14.5 14.5 14.5 14.5 14.5 14.5 14.5 14.5
15.5 15.5 15.5 15.5 15.5 15.5 15.5 15.5
16.5 16.5 16.5 16.5 16.5 16.5 16.5 16.5
17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5
18.5 18.5 18.5 18.5 18.5 18.5 18.5 18.5
19.5 19.5 19.5 19.5 19.5 19.5 19.5 19.5
20.5 20.5 20.5 20.5 20.5 20.5 20.5 20.5
21.5 21.5 21.5 21.5 21.5 21.5 21.5 21.5
22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5
23.5 23.5 23.5 23.5 23.5 23.5 23.5 23.5
24.5 24.5 24.5 24.5 24.5 24.5 24.5 24.5
25.5 25.5 25.5 25.5 25.5 25.5 25.5 25.5
26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5
27.5 27.5 27.5 27.5 27.5 27.5 27.5 27.5
28.5 28.5 28.5 28.5 28.5 28.5 28.5 28.5
29.5 29.5 29.5 29.5 29.5 29.5 29.5 29.5
30.5 30.5 30.5 30.5 30.5 30.5 30.5 30.5
31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5
32.5 32.5 32.5 32.5 32.5 32.5 32.5 32.5
33.5 33.5 33.5 33.5 33.5 33.5 33.5 33.5
34.5 34.5 34.5 34.5 34.5 34.5 34.5 34.5
35.5 35.5 35.5 35.5 35.5 35.5 35.5 35.5
36.5 36.5 36.5 36.5 36.5 36.5 36.5 36.5
37.5 37.5 37.5 37.5 37.5 37.5 37.5 37.5
38.5 38.5 38.5 38.5 38.5 38.5 38.5 38.5
39.5 39.5 39.5 39.5 39.5 39.5 39.5 39.5
40.5 40.5 40.5 40.5 40.5 40.5 40.5 40.5
41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5
42.5 42.5 42.5 42.5 42.5 42.5 42.5 42.5
43.5 43.5 43.5 43.5 43.5 43.5 43.5 43.5
44.5 44.5 44.5 44.5 44.5 44.5 44.5 44.5
45.5 45.5 45.5 45.5 45.5 45.5 45.5 45.5
46.5 46.5 46.5 46.5 46.5 46.5 46.5 46.5
47.5 47.5 47.5 47.5 47.5 47.5 47.5 47.5
48.5 48.5 48.5 48.5 48.5 48.5 48.5 48.5
49.5 49.5 49.5 49.5 49.5 49.5 49.5 49.5
50.5 50.5 50.5 50.5 50.5 50.5 50.5 50.5
51.5 51.5 51.5 51.5 51.5 51.5 51.5 51.5
52.5 52.5 52.5 52.5 52.5 52.5 52.5 52.5
53.5 53.5 53.5 53.5 53.5 53.5 53.5 53.5
54.5 54.5 54.5 54.5 54.5 54.5 54.5 54.5
55.5 55.5 55.5 55.5 55.5 55.5 55.5 55.5
56.5 56.5 56.5 56.5 56.5 56.5 56.5 56.5
57.5 57.5 57.5 57.5 57.5 57.5 57.5 57.5
58.5 58.5 58.5 58.5 58.5 58.5 58.5 58.5
59.5 59.5 59.5 59.5 59.5 59.5 59.5 59.5
60.5 60.5 60.5 60.5 60.5 60.5 60.5 60.5
61.5 61.5 61.5 61.5 61.5 61.5 61.5 61.5
62.5 62.5 62.5 62.5 62.5 62.5 62.5 62.5
Done!
