A kernel compiled with the option [font=“Courier New”]–ptxas-options=-v[/font] seems to be displaying erroneous [font=“Courier New”]lmem[/font] (local memory) statistics when [font=“Courier New”]sm_20[/font] GPU architecture is specified. The same gives meaningful lmem statistics with [font=“Courier New”]sm_10[/font], [font=“Courier New”]sm_11[/font], [font=“Courier New”]sm_12[/font] and [font=“Courier New”]sm_13[/font].
Can someone clarify if the sm_20 lmem statistics need to be read differently or they are plain wrong?
Here is the kernel:
__global__ void fooKernel( int* dResult )
const int num = 1000;
int val[num];
for ( int i = 0; i < num; ++i )
val[i] = i * i;
int result = 0;
result += val[i];
*dResult = result;
return;
[font=“Courier New”]–ptxas-options=-v[/font] and [font=“Courier New”]sm_20[/font] report:
1>ptxas info : Compiling entry function '_Z9fooKernelPi' for 'sm_20'
1>ptxas info : Used 5 registers, 4+0 bytes lmem, 36 bytes cmem[0]
[font=“Courier New”]–ptxas-options=-v[/font] and [font=“Courier New”]sm_10 / sm_11 / sm_12 / sm_13[/font] report:
1>ptxas info : Compiling entry function '_Z9fooKernelPi' for 'sm_10'
1>ptxas info : Used 3 registers, 4000+0 bytes lmem, 4+16 bytes smem, 4 bytes cmem[1]
sm_20 reports a lmem of [font=“Courier New”]4 bytes[/font], which is simply not possible if you see the [font=“Courier New”]4x1000 byte[/font] array being used in the kernel. The older GPU architectures report the correct [font=“Courier New”]4000 byte[/font] lmem statistic.
This was tried with CUDA 3.2. I have referred to the Printing Code Generation Statistics section of the NVCC manual (v3.2), but it does not help explain this anomaly.
