Hardware - GPU (V100)
Hardware - CPU -
Operating System (Ubuntu)
Riva Version (1.7.0 and 1.8.0)
TLT Version (if relevant)
How to reproduce the issue? (This is for errors. Please share the command and the detailed log here)
We are trying to use riva-contact
as starter example;
- Starting Riva 1.7 or 1.8 (both have this issue) backend (served over 8001)
- Starting Riva client 1.7 or 1.8 for running
npm start run
(server over 6006)
Sometimes npm start run
works well and we are able to use it, but once we interrupt the npm server and try to restart it falls into UNIMPLEMENTED 12. After this, we need to restart the machine and try many times to get it to work again. It seems rather we are receiving this error almost randomly.
Client at ::ffff:xx.xx.xx.14 disconnected. Reason: client namespace disconnect
Client connected from ::ffff:xx.xx.xx.14
Initializing Riva ASR
Error via streamingRecognize callback
Error: 12 UNIMPLEMENTED:
at Object.exports.createStatusError (/workspace/lc/node_modules/grpc/src/common.js:91:15)
at ClientDuplexStream._emitStatusIfDone (/workspace/lc/node_modules/grpc/src/client.js:233:26)
at ClientDuplexStream._receiveStatus (/workspace/lc/node_modules/grpc/src/client.js:211:8)
at Object.onReceiveStatus (/workspace/lc/node_modules/grpc/src/client_interceptors.js:1311:15)
at InterceptingListener._callNext (/workspace/lc/node_modules/grpc/src/client_interceptors.js:568:42)
at InterceptingListener.onReceiveStatus (/workspace/lc/node_modules/grpc/src/client_interceptors.js:618:8)
at /workspace/lc/node_modules/grpc/src/client_interceptors.js:1127:18 {
code: 12,
metadata: Metadata { _internal_repr: {}, flags: 0 },
details: ''
/workspace/lc/node_modules/express-socket.io-session/lib/hash.js:12
JSON.stringify(sess, function(key, val) {
TypeError: Converting circular structure to JSON
--> starting at object with constructor 'ClientDuplexStream'
| property '_writableState' -> object with constructor 'WritableState'
| property 'afterWriteTickInfo' -> object with constructor 'Object'
--- property 'stream' closes the circle
at JSON.stringify (<anonymous>)
at hash (/workspace/lc/node_modules/express-socket.io-session/lib/hash.js:12:8)
at isSaved (/workspace/lc/node_modules/express-socket.io-session/index.js:96:51)
at shouldSave (/workspace/lc/node_modules/express-socket.io-session/index.js:112:8)
at /workspace/lc/node_modules/express-socket.io-session/index.js:66:10
at processTicksAndRejections (internal/process/task_queues.js:77:11)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! riva-contact@1.0.0 start: `node server.js "run"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the riva-contact@1.0.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-01-07T14_39_38_068Z-debug.log
