I feel bad asking this. I know from the API pages that cudaerror_t = 13 “indicates that the symbol name/identifier passed to the API call is not a valid name or identifier.” But, I am mirroring the steps I took in another program to do something very similar.
The data types:
struct GpuRismManagement {
int istep; // Number of steps since start/restart
int np; // Number of data points (first dimension length)
int nvec; // Maximum number of vectors
double restart; // Ratio of the current residual to the minimum residual found
// that causes a restart
double delta; // Coefficient for residual gradient, between 0 and 1.
double tol; // Target residual
float* overlap; // The overlap matrix
float* ri; // An array of vector data, np by nvec
float* xi; // An array of residual data, np by nvec
int* vecMap; // Maps vectors order onto ri and xi. E.g. vecMap(0) gives the
// index of xi or ri that is most recently updated
typedef struct GpuRismManagement gpuRismInfo;
struct HostRismManagement {
gpuFloat overlap; // The overlap matrix
gpuFloat ri; // An array of vector data, np by nvec
gpuFloat xi; // An array of residual data, np by nvec
gpuInt vecMap; // Maps vector order onto ri and xi. E.g. vecMap(0) gives the
gpuRismInfo gpuConst; // See type definition above. This hold constants (including
// pointers) that the GPU will need in order to carry out work.
GpuFloat and GpuInt are data types I have defined that track partnered arrays of floats and ints on the host and on the device, with associated functions for downloading and uploading the data. Note that a gpuRismInfo type lives inside a hostRismInfo type, and the gpuRismInfo type contains pointers to the device-side arrays of the GpuFloat and GpuInt types inside the hostRismInfo type.
1.) In one code file, let’s call it MyCudaUnit.cu, I declare up at the top “device constant gpuRismInfo cRISM;” and the function:
// SetRismImage: function to establish a GPU RISM data structure on the device, with pointers
// to all of the device-allocated memory as well as constants describing the
// simulation conditions.
// Arguments:
// hRISM: the repository for all parameters and data on the host
extern "C" void SetRismImage(hostRismInfo *hRISM)
cudaError_t status;
status = cudaMemcpyToSymbol((void**)&cRISM, &hRISM->gpuConst, sizeof(gpuRismInfo));
if (status != cudaSuccess) {
printf("SetRismImage >> Unable to copy gpuRismInfo struct to the "
"device (error %d).\n", (int)status);
exit(1);
2.) In another code file, let’s call it MyCLayerThatCallsCuda.c, I declare up at the top static “hostRismInfo hRISM;” and a function in there that calls “SetRismImage(&hRISM);”
3.) In a third code file, let’s call it MyFortranLayerWhichCallsC.F90, I call the function in MyCLayerThatCallsCuda.c that in turn calls SetRismImage(&hRISM).
But, when I run this, I am getting that dreaded error 13. Anyone have ideas? I also noticed that in other codes my team and I have omitted the (void**)& in front of the hRISM such that the device constant is passed as a value, not a void pointer, as the first argument of cudaMemcpyToSymbol. If I do that, which again works in other codes, I now get cudaerror_t 77, and I don’t know what that means from reading the API documentation.
Dave
