• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 6.3 • JetPack Version (valid for Jetson only) • TensorRT Version CUDA12.1 and TRT8.5.3.1 • NVIDIA GPU Driver Version (valid for GPU only) 535.104.05 • Issue Type( questions, new requirements, bugs) questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hello, has this bug been fixed? I encountered the same issue when developing with C language.
When the program runs for a while, it will throw an error. The error message is as follows:
Error (406): Not Acceptable
warning source: source
SOURCE STATE CHANGE NO PREROLL
Here is the command I used to start the container: “sudo docker run --privileged --gpus all -itd --name ds63_container -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY nvcr.io/nvidia/deepstream:6.3-triton-multiarch”.
I can run ‘deepstream-test1’ and ‘deepstream-app’ without any problems.
Thank you for your reply, I will try this approach. During testing, I found that sometimes when a new video stream is added, the state of the source_bin changes to GST_STATE_CHANGE_FAILURE, and subsequently all new video streams added remain in the GST_STATE_CHANGE_NO_PREROLL state. Have you encountered this situation before?
Thank you for your reply.I made modifications based on this foundation, and I dynamically create and destroy osd and sink plugins on the demux downstream when adding sources dynamically. However, the stability of the running is not very reliable. Do you have similar examples or suggestions in this case?
