Hardware Platform: DRIVE AGX Xavier™ Developer Kit
Software Version: DRIVE Software 9 → DRIVE Software 10
Host Machine Version: native Ubuntu 18.04.04 LTS
SDK Manager Version: 1.0.1.6343
Bord HW Ver: T194-A/B CHIP REV.A02 BR:03 | E3550: 699-63550-0001-500 C RW0
i have problems to upgrade our ATX from Software 9 to 10. I get following error messages in the SDK Manager:
12:57:13 INFO : Flash Xavier A+B in parallel : Flashing for Partition B_mts-preboot (Size: 23968 bytes, Time: 1.268 seconds)
12:57:13 INFO : Flash Xavier A+B in parallel : 14% doneFlashing for Partition B_mts-mce (Size: 140048 bytes, Time: 1.763 seconds)
12:57:13 INFO : Flash Xavier A+B in parallel : Flashing for Partition B_mts-bootpack 15% done 16% done 17% donerm: cannot remove '/home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_uRNbgXnnLs/flash-images': Directory not empty
12:57:13 INFO : Flash Xavier A+B in parallel : Flashing process exited with error 5
12:57:13 INFO : Flash Xavier A+B in parallel : Error in flashing!
12:57:13 INFO : Flash Xavier A+B in parallel : pdkinstaller cannot continue! Check the log file for details: /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/pdkinstaller/pdkinstaller.log
12:57:13 ERROR : Flash Xavier A+B in parallel : [exec_command]: /bin/bash -c cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable; [error]: exit status 144
12:57:13 INFO : Flash Xavier A+B in parallel : [ Component Install Finished with Error ]
12:57:13 INFO : Flash Xavier A+B in parallel : [ 596.05 MB used. Disk Avail: 78.58 GB ]
12:57:13 INFO : Flash Xavier A+B in parallel : [ NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP Install took 14m34s ]
12:57:13 ERROR : Flash Xavier A+B in parallel : [error]: Run commands failed at step Install: command cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable finished with error
12:57:13 ERROR : Flash Xavier A+B in parallel : command terminated with error
12:57:14 ERROR : Flash Xavier A+B in parallel : Install 'Flash Xavier A+B in parallel' failure, command < using adapter to install NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX to /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX > terminated with error.
12:57:15 INFO : All done!
pdkinstaller.log (571.5 KB)
NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP.log (109.2 KB)
as i browsed through the logfiles i found this in
~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump
Platform version 7.0
supports 262144 Bytes MAX_PAYLOAD
This build is for NVIDIA embedded bootburn
Build time : May 16 2017 01:26:13
serial number to adb : 2P10U341O000004VV0M0
Could not find a device online
command options used = -b e3550b03-t194 -B qspi -x /dev/ttyUSB3 --updtcfga gos1-fs:dirname:/home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/targetfs_a --updtcfgb gos1-fs:dirname:/home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/targetfs_b -w
------------ Stack Trace ------------
stack frame 0 - 329 AbnormalTermination /home/.../nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
stack frame 1 - 48 CheckUSBServiceInit /home/.../nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_adb.sh
stack frame 2 - 2942 FlashImages /home/.../nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
stack frame 3 - 404 source /home/.../nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_active.sh
stack frame 4 - 1270 main /home/.../nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh
Tool OutPut:
Bus 003 Device 022: ID 0955:7100 NVidia Corp. Tegra Device
Tool OutPut to stderr:
error-adb-timeout
TegraALog_eRLt6PSxDk.log (19.1 KB) TegraBLog_j1nYCd5EAc.log (24.0 KB)
