Hello.
I’m trying to port a Big Integer architecture I wrote on C to CUDA, and I’m getting a 719 error on “random” situations.
I may assume it’s an issue with memory, because when testing, I get the error sooner or later depending on the integer length.
To sum up, my main test code is the following
//BITesting.cu//
int main() {
/*************************** TESTING v2 INI ***************************/
struct BigInteger* a = (struct BigInteger*)malloc(sizeof(struct BigInteger));
//char* s = "1111111111222222222233333333334444444444555555555566666666667777777777888888888899999999990000000000";
char* s = "1";
//char* s = "123";
int i = 0;
newBI_testing(a, s, 0);
printf("<");
for (; i <= a->count; i++)
printf("%i", a->n[i]);
printf(">\n");
printf("Ending...\n");
/*************************** TESTING v2 END ***************************/
return 0;
Then, the main code will run the test:
* newBI_testing
* Preámbulo para pruebas
void newBI_testing(void* dst, char* s, int sig) {
//variables para CUDA
struct BigInteger* cu_dst;
struct BigInteger* cu_b;
char* cu_s;
int* cu_sig;
//allocamos memoria
cudaMalloc((void**)& cu_dst, sizeof(struct BigInteger));
cudaMalloc((void**)& cu_b, sizeof(struct BigInteger));
cudaMalloc((void**)& cu_s, sizeof(char) * strlen(s));
cudaMalloc((void**)& cu_sig, sizeof(int));
//copiamos s a cu_s y sig a cu_sig
cudaMemcpy(cu_s, s, sizeof(char)* strlen(s), cudaMemcpyHostToDevice);
cudaMemcpy(cu_sig, &sig, sizeof(char)* strlen(s), cudaMemcpyHostToDevice);
printf("START: %d\n", clock());
//llamamos a CUDA
_newBI_testing<<<1, 1>>>(cu_dst, cu_s, cu_sig, cu_b);
//printf("Last Error: %i\n", cudaGetLastError());
//sincronizamos
cudaDeviceSynchronize();
printf("END: %d\n", clock());
//printf("Last String Error: %s\n", cudaGetErrorString(cudaGetLastError()));
//copiamos de vuelta
cudaMemcpy(dst, cu_dst, sizeof(struct BigInteger), cudaMemcpyDeviceToHost);
* _newBI_testing
* Lanzadera para _newBI
__global__ static void _newBI_testing(void* dst, char* s, int* sig, void* b) {
_newBI(dst, s, sig);
_newBI(b, s, sig);
int i = 0;
for (; i < 1000; i++) {
printf("I: %i\n", i);
_add(dst, b);
It calls “_newBI” function twice (a function that creates a BigInteger structure, basically, an integer-array representation for the given string, then make “_add” (that just makes “dst = dst + b”) a couple of times.
With this setting, I got the 719 error when “i = 354”.
BigInteger struct:
//struct
struct BigInteger {
int count;
int n[4096];
_newBI function
__device__ int BLOCK_SIZE = 256;
__device__ int NUM_BLOCKS = 16; /*(CU_MAX_LENGTH + BLOCK_SIZE - 1) / BLOCK_SIZE;*/
* Función _newBI.
* Genera un nuevo dato BI a partir del string que recibe como entrada.
* Se cargan en orden inverso para permitir el crecimiento de manera sencilla.
__device__ void _newBI(void* dst, char* s, int* sig){
//longitud del string
int i = cu_strlen(s) - 1;
//limpiamos el array
_clean<<<NUM_BLOCKS, BLOCK_SIZE>>>(dst);
//validamos que no sobrepase el límite establecido
if (i > CU_MAX_LENGTH) {
_showError(1);
return;
//semáforo para clean.
//mientras tanto, se puede ir validando la longitud (no afecta a ret)
//recorremos el string y lo guardamos en integers
newBI_fill<<<NUM_BLOCKS, BLOCK_SIZE >>>(dst, s, i);
//ajustamos la longitud
((struct BigInteger*)dst)->count = i;
//semáforo para newBI_fill
//mientras tanto, vamos ajustando la longitud de ret
//¿ha habido algún error en newBI_fill?
if (CU_RET > 0)
return;
//validamos signo
if (*sig == -1)
((struct BigInteger*)dst)->n[((struct BigInteger*)dst)->count] *= -1;
* Función _newBI_fill.
* Rellena a.n de manera paralela a partir del string s de manera inversa
* usando len como punto medio
__global__ static void newBI_fill(void* va, char* s, int len) {
int index = blockIdx.x * blockDim.x + threadIdx.x;
int stride = blockDim.x * gridDim.x;
int i = 0;
char c;
for (i = index; i <= len; i += stride) {
if (i > len)
//puede que len no sea divisible por 16 y por tanto debemos controlar el final
return;
//vamos capturando los caracteres de manera inversa
c = (int)(s[len - i] - 48);
if (c >= 0 && c <= 9)
((struct BigInteger*)va)->n[i] = c;
else {
_showError(2);
return;
* Función cu_strlen.
* Sinónimo de strlen C
__device__ static int cu_strlen(char* s) {
int ret = 0;
while (*s++ != '\0')
++ret;
return ret;
* Función _clean.
* Limpia la estructura
__global__ static void _clean(void* va){
int i = 0;
for (i = index; i < CU_MAX_LENGTH; i += stride)
((struct BigInteger*)va)->n[i] = 0;
So, as I explained, it moves (on backwards order) each char to an int representation on the struct, using paralelysm.
I had to “copy” strlen function as it does not work on kernel, but not big deal.
Then, on the “_add” function:
* Función _add. Usar para sumar dos números.
* Realiza la operación de suma, teniendo en cuenta los signos de los números.
* Si los signos son iguales, hace una suma, sino, una resta.
__device__ void _add(void* va, void* vb) {
//validamos los datos antes de tratarlos
_validateBI<<<1, 1>>>(va);
_validateBI<<<1, 1>>>(vb);
//semáforo
//¿Ha habido algún error?
if (CU_RET > 0)
return;
//delegamos en la función estática
_pAdd(va, vb);
* Función _pAdd. Usar para sumar dos números.
__device__ static void _pAdd(void* va, void* vb) {
//calcumamos signum
int sig = _signum(((struct BigInteger*)va)->n[((struct BigInteger*)va)->count],
((struct BigInteger*)vb)->n[((struct BigInteger*)vb)->count]);
//normalizamos los operandos
if (sig == 10)
//a negativo, b positivo. Cambiamos el signo de "a" y hacemos suma
((struct BigInteger*)va)->n[((struct BigInteger*)va)->count] *= -1;
else if (sig == 1)
//b negativo, a positivo. Cambiamos el signo de "b" y hacemos suma
((struct BigInteger*)vb)->n[((struct BigInteger*)vb)->count] *= -1;
else if (sig == 11) {
//a negativo, b negativo. Cambiamos signos y hacemos suma
//si ambos signos son iguales, se suma, sino, se resta
if (sig == 0 || sig == 11)
_addition(va, vb);
else
_pSub(va, vb);
if (sig == 10 || sig == 11)
//en estos casos, siempre se le va la vuelta al signo
* Función _addition.
* Simula la operación a = a + b
__device__ static void _addition(void* va, void* vb) {
int limit;
int min;
int swap;
int move;
//asumimos que a tiene la mayor longitud
limit = ((struct BigInteger*)va)->count;
//asumimos que b tiene la menor longitud
min = ((struct BigInteger*)vb)->count;
//indicador de necesidad de arrastre
move = 0;
//si no es así, rectificamos
if (((struct BigInteger*)vb)->count > limit) {
//intercambiamos limit y min
swap = limit;
limit = min;
min = swap;
move = 1;
//sumamos los dígitos que coinciden
_addition_merge<<<NUM_BLOCKS, BLOCK_SIZE>>>(va, vb, min);
//los dígitos que no coinciden los traspasamos
if (move == 1) {
_addition_move <<<NUM_BLOCKS, BLOCK_SIZE >>>(va, vb, min + 1, limit);
((struct BigInteger*)va)->count = limit;
//Esperamos que las dos funciones terminen
//gestionamos el acarreo
* Si a->count = b->count --> min = a->count (Se tratarán todos los dígitos)
* Si a->count > b->count --> min = b->count (Se hará la gestión en dos partes)
* Si a->count < b->count --> min = a->count (Se hará la gestión en dos partes)
_carryAdd(va, 1, min);
* Función _addition_merge.
* Simula la operación a = a + b de un dígito
__global__ static void _addition_merge(void* va, void* vb, int min) {
int i = 0;
for (i = index; i <= min; i += stride) {
if (i > min)
return;
else
((struct BigInteger*)va)->n[i] += ((struct BigInteger*)vb)->n[i];
* Función _addition_move.
* Mueve un dígito que existe en "b" pero no en "a"
__global__ static void _addition_move(void* va, void* vb, int offset, int min) {
int index = blockIdx.x * blockDim.x + threadIdx.x + offset;
int i = 0;
if (i > min)
return;
else
((struct BigInteger*)va)->n[i] = ((struct BigInteger*)vb)->n[i];
* Función _carryAdd.
* Gestiona el acarreo de la suma. Si hay movimiento de datos, se mueve el valor 1 a ret.
* De esta manera, podemos llamar hasta que no haya cambios en el acarreo.
__device__ static void _carryAdd(void* va, int move, int min) {
int i = 0;
int acc;
int limit;
acc = 0;
//move == 1 --> sabemos que hay una parte no común. En min está el límite de la parte común
if (move == 1)
limit = min;
else
//recorremos a y vamos sumando el acarreo de la parte común
for (; i <= limit; i++) {
//sumamos acarreo
((struct BigInteger*)va)->n[i] += acc;
//como acc es int, podemos dividir entre 10 y sacar el acarreo
acc = ((struct BigInteger*)va)->n[i] / 10;
if (acc > 0)
//normalizamos el número
((struct BigInteger*)va)->n[i] = ((struct BigInteger*)va)->n[i] % 10;
if (move == 1) {
//queda parte no común. Acarreamos hatsa que acc sea 0, ya que la parte no común ya está normalizada
while (acc > 0 && i <= ((struct BigInteger*)va)->count) {
//sumamos acarreo
if (acc > 0)
i++;
//si ha quedado acarreo, lo guardamos al final;
if (acc > 0) {
if (((struct BigInteger*)va)->count == CU_MAX_LENGTH)
_showError(1);
else
((struct BigInteger*)va)->n[++(((struct BigInteger*)va)->count)] = acc;
* Función _signum.
* Devuelve la cantidad de datos negativos que hay en la operación.
__device__ static int _signum(int a, int b) {
int ret = 0;
if (a < 0)
ret = 10;
if (b < 0)
++ret;
return ret;
* Función _validateBI
* Valida que todos los datos del BI sean coherentes.
* Se crea como __globlal__ para poder llamarse en paralelo.
__global__ void _validateBI(void* a) {
int* t = (int*)(malloc(sizeof(int)));
if (t == NULL || a == NULL) {
_showError(98);
return;
memcpy(t, (int*)a, sizeof(int));
//validamos la variable de longitud
if (*t < 0 || *t > CU_MAX_LENGTH) {
_showError(99);
free(t);
return;
memcpy(t, (int*)a + 1, sizeof(int));
//validamos el resto de dígitos, que pueden ser positivos o negativos
validateBI_loop <<<NUM_BLOCKS, BLOCK_SIZE>>>(a);
//liberamos memoria
free(t);
//sincronizamos antes de terminar
//la memoria de "t" se puede eliminar sin problemas
* Función loop_validateBI
* Valida BigInteger.n de manera paralela
__global__ void validateBI_loop(void* a) {
int i = 0;
if (t == NULL)
_showError(98);
memcpy(t, (int*)a + (index + 1), sizeof(int));
for (i = index; i < CU_MAX_LENGTH; i += stride) {
//si no está en el rango [-9, +9], damos error
if (*t < -9 || *t > 9) {
_showError(99);
free(t);
return;
memcpy(t, (int*)a + (i + 1), sizeof(int));
free(t);
It validates the format of both parameteres, then add each correlative array common position, while at the same time moves the even positions from the second array to the first; then checks the result, it works fine (or should).
So, maybe it’s a simple error… I’m a bit new on CUDA programming, or it’s a memory flaw, or a void-BigInteger casting issue…
Can anyone help me, please?
I also did a CUDA_MEMCHECK on the program, so it may help out_CUDA_MEMCHECK.txt (8.1 KB)
I’m not asking for some magic “change this line” or “do not do this part here”… I want to understand the root cause, so please ask me if there’s any info I can provide.
I’m working on Windows 10, using Visual Studio plugin for CUDA
(PS: I don’t want to make spam, but the full code is on GitHub, so if necessary, please ask and I provide the link so you can review full source code.
Thanks a lot
