I am new to Linux (Windows programmer since 1995) and figure this is a configuration issue, attempting to load Help from a local repository which does not seem to exist.
I have the same issue accessing help from Nsight Eclipse with an Ububtu 18.04 installation. I suspect a web-server issue (e.g. Tomcat) but after the amount of difficulty with the installation process, am reluctant to make any changes.
Did you ever identify a good solution to this issue?
I agree, exactly the same problem. I dug around and found index.html under usr/local/cuda-10.2/doc/html, it’s sort of helpful but does not really solve the problem.
Basically, can NVidia provide support for NSight Eclipse 10.2? Anyone working on the Nano / wishing to cross compile for the Nano… cannot use the latest CUDA as it’s not supported. But all the help and reference for NSight Eclipse is based on the latest 11.2 at the time of writing. Some settings / dialogs have changed since then and it seems impossible to find help. And, as mentioned above, the built-in help in NSight Eclipse is just empty. Files not there, not on system, cannot find them on the web.
HELP PLEASE!!!
