Hi everybody. I installed DeepStreamSDK 6.0.1 on my Nano everything went well with no error at all. When I’m trying to execute sudo gst DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
I’m getting error. sudo: GST: command not found
Can somebody tell me what may cause this ?
Hello @72erdelyi,
We believe the issue might be that you are executing gst DEBUG=3
as separate commands/arguments.
Please remember that GST_DEBUG is actually an environment variable.
Therefore, you should be able to use it as follows:
sudo GST_DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
Please let us know how that goes.
And do not hesitate to reach out if you are still facing issues or require further help.
regards,
Andrew
Hi. Indeed that was the issue. Thanks for the help
