Usually, I use the official Isaac ROS dev container (here) in order to use Nav2 stack.
Today I cannot build anymore the run_dev.sh script.
I run into the following issue:
458.4 …failed updating 2 targets…
458.4 …skipped 10 targets…
458.4 …updated 17020 targets…
1 warning found (use docker --debug to expand):
- UndefinedVar: Usage of undefined variable ‘$CMAKE_PREFIX_PATH’ (line 277)
Dockerfile.aarch64:383
382 | # Current libboost-dev apt packages are < 1.78, so install from tar.gz
383 | >>> RUN --mount=type=cache,target=/var/cache/apt
384 | >>> #curl -L https://archives.boost.io/release/1.80.0/source/boost_1_80_0.tar.gz -o /tmp/boost.tar.gz
385 | >>> wget -O /tmp/boost.tar.gz Download boost_1_80_0.tar.gz (Boost C++ Libraries)
386 | >>> && (cd /tmp && tar xzf boost.tar.gz)
387 | >>> && cd /tmp/boost_1_80_0
388 | >>> && ./bootstrap.sh --prefix=/usr
389 | >>> && ./b2 install
390 | >>> && rm -rf /tmp/boost*
| 391 |
| ERROR: failed to build: failed to solve: process “/bin/bash -c wget -O /tmp/boost.tar.gz Download boost_1_80_0.tar.gz (Boost C++ Libraries) && (cd /tmp && tar xzf boost.tar.gz) && cd /tmp/boost_1_80_0 && ./bootstrap.sh --prefix=/usr && ./b2 install && rm -rf /tmp/boost*” did not complete successfully: exit code: 1 |
| /orin_ssd/isaac_ros_dev/src |
I think that there’s an issue with ./b2 install command.
Do you have any suggestion?
