We are bringing a new custom board and facing streaming error :
kworker/2:3-105 [002] .... 339.372889: rtcpu_vinotify_event: tstamp:11240335732 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:359687478112 data:0x0000000000000010
kworker/2:3-105 [002] .... 339.372890: rtcpu_vinotify_event: tstamp:11240335872 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:359687492992 data:0x00000000000003c9
kworker/2:3-105 [002] .... 339.428902: rtcpu_vinotify_error: tstamp:11240756599 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:359704176064 data:0x00000000000003c9
kworker/2:3-105 [002] .... 339.428907: rtcpu_vinotify_event: tstamp:11241013853 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:359703478944 data:0x0000000000000020
However, the streaming seems ok if I maximize the clocks of the pipeline’s elements :
#!/bin/bash
[ "$UID" != "0" ] && echo 'Root access is required.' && exit 1
max-clock()
local BASE="/sys/kernel/debug/bpmp/debug/clk"
local name="$1"
local clock_base="${BASE}/${name}"
echo $(cat "${clock_base}/max_rate") > "${clock_base}/rate"
echo 1 > "${clock_base}/mrq_rate_locked"
echo -n "${name} clock rate is:"
cat "${clock_base}/rate"
for clock in vi isp emc nvcsi; do
max-clock "$clock"
done
Output :
vi clock rate is:460800000
isp clock rate is:576000000
emc clock rate is:1866000000
nvcsi clock rate is:314000000
Do you think that it is relevant to the hardware, especially to the MIPI-CSI2 signals ?
jnx_trace.txt (30.1 KB)
Best Regards,
Khang
I re-tested and with the maximization of only nvcsi clock as above, the stream still worked. But without it, the stream was frozen.
Hi again,
Digging more deeply and by seeing that /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate already has same value as /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate (which is 314000000) just after a reboot, the following operation made the streaming work :
# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
Does it mean that the above command forces the nvcsi clock to be max value (314000000) permanently?
Best regards,
Khang
Adjust the pix_clk_hz/serdes_pix_clk_hz in device tree to acquire high clocks for your case.
Hi @ShaneCCC ,
Thanks for your reply.
ShaneCCC:
serdes_pix_clk_hz
I do not use the GMSLx serializer / deserializer so no need to add/adjust serdes_pix_clk_hz. Do you confirm ?
By the way, based on your experience do you think that the pix_clk_hz needs to be higher for communicating with higher clocks ?
The current device-tree configuration is as below :
mode0 { /* MODE_1920X1080_30FPS */
mclk_khz = "24000";
set_mode_delay_ms = "5000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
pixel_phase = "uyvy";
pixel_t = "yuv_uyvy16";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1816577";/*1.816577 */
max_framerate = "60000000";/*60fps*/
step_framerate = "1";
default_framerate = "60000000";/*60fps*/
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
Best Regards,
Khang
Yes, don’t need serdes_pix_clk_hz for none GMSLx serializer / deserializer design.
You can increase the pix_clk_hz to try.
Hi @ShaneCCC
khang.l4es:
No need to increase “mclk_multiplier” ? I tested with mclk_multiplier=30 and the result was the same. Please note that this is an FCB camera and it does not need MCLK from the Jetson.
Hi @ShaneCCC ,
Effectively, increasing the pix_clk_hz to 4x the original value works for this specific board/hardware. I don’t know yet how to explain but we did have a 2-lane MIPI-CSI2 reference configuration working with pix_clk_hz=74250000, then it continued working well on another board with another 4-lane MIPI-CSI2 configuration, but with the board/hardware in question (also with 4-lane MIPI-CSI2 configuration), we have to increase it 4 times.
We also tested the 2x increment but it did not work even though there was image/frame getting updated half of the screen and the other half was green while in the case pix_clk_hz=74250000, there was 2 smaller frames/images filling the half of the screen and frozen (as below) :
That led me decide to increase to 4x the pix_clk_hz.
Does the bit depth are the same?
Reference/working 2-lane configuration based on Jetpack-4.6.x
mode0 { /* VEYE327_MODE_1920X1080_30FPS */
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_b";
phy_mode = "DPHY";
//discontinuous_clk = "no";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
default_gain = "16"; /* 1.00x */
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30 fps */
default_framerate = "30000000"; /* 30 fps */
min_exp_time = "13"; /* us */
max_exp_time = "333333"; /* us */
default_exp_time = "2495"; /* us */
Working 4-lane configuration on one board based on Jetpack-5.0.2 in which there’s presence of dynamic_pixel_bit_depth and csi_pixel_bit_depth :
mclk_khz = “24000”;
set_mode_delay_ms = “5000”;
num_lanes = “4”;
tegra_sinterface = “serial_a”;
phy_mode = “DPHY”;
discontinuous_clk = “yes”;
dpcm_enable = “false”;
cil_settletime = “0”;
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
gain_factor = "10";
Above configuration did not work with the board/hardware in question if pix_clk_hz had not been increased 4 times.
Best Regards,
Khang
Could you check the nvcsi/vi/emc clocks is the same with JP4.x?
system
Closed
July 17, 2024, 6:15am
14
