Hello!
I will testing the capabilities to use nvblox on the jetson Orin Nano of 4GB, 8GB and Orin NX. I have an AGX Orin developer kit. I followed the instructions to use the AGX as a 4GB nano manually without SDK manager. Use the latest version to format. It worked fine and then I followed the instructions to create the images using realsense. I tried to compile it completely, with the ros2_humble.realsense configuration but it did not work, then I removed realsense and when compiling the problem continues. Compilation failed at [stage-0 17/22] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone GitHub - moveit/moveit_task_constructor: A hierarchical multi-stage manipulation planner. The logs are the same in both situations, but i think the most important part is the following Error: 243.2 CMake Error at CMakeLists.txt:15 (find_package):
243.2 By not providing “Findpy_binding_tools.cmake” in CMAKE_MODULE_PATH this
243.2 project has asked CMake to find a package configuration file provided by
243.2 “py_binding_tools”, but CMake did not find one.
243.2
243.2 Could not find a package configuration file provided by “py_binding_tools”
243.2 with any of the following names:
243.2
243.2 py_binding_toolsConfig.cmake
243.2 py_binding_tools-config.cmake
243.2
243.2 Add the installation prefix of “py_binding_tools” to CMAKE_PREFIX_PATH or
243.2 set “py_binding_tools_DIR” to a directory containing one of the above
243.2 files. If “py_binding_tools” provides a separate development package or
243.2 SDK, be sure it has been installed.
I installed docker and nvidia-jetpack (6.0+b106) following all the documentation. It seems to be the same issue raised on github
