I’m running Ubuntu 22.04 on my host with ROS 2 Humble, and I have an Intel RealSense D455 publishing image and IMU topics.
My goal is to send these topics into a Docker container running Ubuntu 20.04 + ROS Noetic, where I plan to run a SLAM framework that only supports ROS 1.
To achieve this, I’m trying to use the Isaac ROS Nitros Bridge, following this official guide:
However, I’ve faced the following issues:
- Docker build fails due to missing packages like
libxtensor-devorros-humble-ros-basewhen building from Ubuntu 20.04. rosdepthrows errors forurdfdom_headersnot being defined forfocal.- There is a conflict in instaling Humble (ROS 2) in Docker container.
Main Question:
What is the recommended way to pass D455 topics (images/IMU) from ROS 2 Humble (host) into a ROS 1 Noetic container, ideally minimizing latency?
Should I:
- Install everything manually from source in a clean ROS Noetic container?
