Hello! I’m trying to create a duplicate of my USB video capture device so that I can stream and record it at the same time. Recording works fine with streamer
, and streaming works find with mplayer
. I have seen people using v4l2loopback
to create additional nodes for their video devices. When I try installing with
sudo apt-get install v4l2loopback-dkms
it produces the following output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following package was automatically installed and is no longer required:
libgconf2-4
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
dkms
Suggested packages:
v4l2loopback-utils
The following NEW packages will be installed:
dkms v4l2loopback-dkms
0 upgraded, 2 newly installed, 0 to remove and 2 not upgraded.
Need to get 89.4 kB of archives.
After this operation, 469 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://ports.ubuntu.com/ubuntu-ports/ trusty-updates/main dkms all 2.2.0.3-1.1ubuntu5.14.04.9 [65.7 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports/ trusty/universe v4l2loopback-dkms all 0.8.0-1 [23.6 kB]
Fetched 89.4 kB in 1min 4s (1,392 B/s)
Selecting previously unselected package dkms.
(Reading database ... 149251 files and directories currently installed.)
Preparing to unpack .../dkms_2.2.0.3-1.1ubuntu5.14.04.9_all.deb ...
Unpacking dkms (2.2.0.3-1.1ubuntu5.14.04.9) ...
Selecting previously unselected package v4l2loopback-dkms.
Preparing to unpack .../v4l2loopback-dkms_0.8.0-1_all.deb ...
Unpacking v4l2loopback-dkms (0.8.0-1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up dkms (2.2.0.3-1.1ubuntu5.14.04.9) ...
Setting up v4l2loopback-dkms (0.8.0-1) ...
Loading new v4l2loopback-0.8.0 DKMS files...
First Installation: checking all kernels...
dpkg: warning: version '*-*' has bad syntax: version number does not start with digit
It is likely that 3.10.67-g458d45c belongs to a chroot's host
Building initial module for 3.10.67-g458d45c
ERROR (dkms apport): kernel package linux-headers-3.10.67-g458d45c is not supported
Error! Bad return status for module build on kernel: 3.10.67-g458d45c (aarch64)
Consult /var/lib/dkms/v4l2loopback/0.8.0/build/make.log for more information.
What should I do? Kernel headers are beyond the scope of my linux experience…
