@DaneLLL, thank you for your response,
can you see any direct way to get v4l2loopback module loaded somehow?
@DaneLLL, could you rewrite the command below in the way it will work for Xavier, please?
gst-launch-1.0 nvcamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
WARNING: erroneous pipeline: no element "nvcamerasrc"
the rest of operations seem to work as listed below:
cd /usr/src/linux-headers-4.9.108-tegra/kernel-4.9
mkdir v4l2loopback
cd v4l2loopback/
git clone https://github.com/umlaeute/v4l2loopback.git
cd v4l2loopback
make
make install
modprobe v4l2loopback devices=1 video_nr=2 exclusive_caps=1
echo options v4l2loopback devices=1 video_nr=2 exclusive_caps=1 > /etc/modprobe.d/v4l2loopback.conf
echo v4l2loopback > /etc/modules
update-initramfs -u
as y attempts like the below don’t appear to work:
gst-launch-1.0 nvarguscamerasrc ! \
> 'video/x-raw(memory:NVMM),width=1024, height=768, \ framerate=120/1, format=NV12' ! nvvidconv flip-method=0 ! nvegltransform ! v4l2sink device=/dev/video2
WARNING: erroneous pipeline: could not parse caps "video/x-raw(memory:NVMM),width=1024,\ height=768,\ \ framerate=120/1,\ format=NV12"
gst-launch-1.0 nvarguscamerasrc v4l2sink device=/dev/video2
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 2592 H = 1458
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:00.808694384
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ..
gst-launch-1.0 nvarguscamerasrc ! v4l2sink device=/dev/video2
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to v4l2sink0
Hi Andrey,
Please try if below pipeline works:
gst-launch-1.0 <b>nvarguscamerasrc</b> ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
Hi DaneLLL,Thank you for your response.
Execution of the sequence above seems to result in the output below:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to nvtee0, nvarguscamerasrc0 can't handle caps video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1
What as well has been attempted so far was:
gst-launch-1.0 -ev nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=640, height=480, framerate=30/1, format=NV12' ! nvvidconv flip-method=0 ! videoconvert ! v4l2sink device=/dev/video2
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)NV12, framerate=(fraction)30/1
Camera index = 0
Camera mode = 2
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Hi Andrey,
Please try with NV12:
gst-launch-1.0 <b>nvarguscamerasrc</b> ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=<b>(string)NV12</b>, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! nvtee ! nvvidconv ! 'video/x-raw, format=(string)I420, framerate=(fraction)30/1' ! tee ! v4l2sink device=/dev/video2
Camera index = 0
Camera mode = 1
seconds to Run = 0
Execution ended after 0:00:00.762815846
Freeing pipeline ...
Hi Andrey,
Please start a new thread for Xavier. Keep this for TX1.
I cannot successfully build v4l2loopback and need your help. Let’s continue in new thread.
please refer to [url]https://devtalk.nvidia.com/default/topic/1043979/jetson-agx-xavier/building-v4l2loopback-and-getting-the-loop-from-csi-to-dev-video/post/5296316/#5296316[/url]
Hi @DaneLLL,
I installed a CSI camera driver which uses v4l2 pipeline to work, but once installing it my v4l2loopback /dev/video2 disappears.
Could you help me with this?
Thank you
Do you use TX1/r32.4.3? Please share information about your device and release version.
Hey @DaneLLL,
Thank you for your support
It is Nano 32.3.1
I am also having the same issue for Xavier Nx, it is 32.4.3
