Description
Using trtexec and get the following error
I guess the reason of this error is in the last operator (greater) didn’t pass the value.
If so how do I fix this error. Rewrite the builtin_op_importers.cpp and rebuild it?
Environment
TensorRT Version : 7.1.3
GPU Type : Jetson TX2 iGPU
Nvidia Driver Version :
CUDA Version : 10.2
CUDNN Version : 8
Operating System + Version : Ubuntu 18.04
Relevant Files
https://drive.google.com/file/d/1Nb0Ky88gD2vC8Vb46phWG4FalgrzeU27/view?usp=sharing
Steps To Reproduce
./trtexec --onnx=test.onnx
Hi @jack_gao ,
Kindly grant access to your onnx model.
Hi @AakankshaS ,
Ok, I have given you the access.
Any update with this error?
Hi @jack_gao ,
I tried running your model and could reproduce the issue.
This is a known issue and will be fixed in future release.
Please stay tuned.
Thank you for your patience.
feral
February 23, 2021, 10:14am
6
Hello NVidia,
I have the same error with efficientdet-d1. Nothing new since August 2020?
F.
same issue for efficientDet-d1
NVES
May 5, 2021, 6:37am
8
Please refer to the installation steps from the below link if in case you are missing on anything
Also, we suggest you to use TRT NGC containers to avoid any system dependency related issues.
similar problem, any solution available?
gkuppa
March 4, 2024, 8:43pm
11
I have the same issue. Please advise.
