ERROR: builtin_op_importers.cpp:3240 In function importUpsample
his @Morganh
I have a.h5 model file which I have converted successfully into onyx file. now I am trying to get art file but after running this command :
!/usr/src/tensorrt/bin/trtexec --explicitBatch --onnx=/path-2-onnx-file/fire_model.onnx --saveEngine=/path-2-save-trt-file/fire_model.trt
I am getting error:
any help?
thanks
Could you share the complete log with --verbose enabled with us?
$ /usr/src/tensorrt/bin/trtexec --verbose ...
@AastaLLL
last logs screenshot.
complete logs are like :
logs.txt (238.0 KB)
thanks
Based on the log, this error is caused by the compatible ONNX format.
It’s expected that the scale parameter in Upsample operation to be a constant.
But it is represented as weights in your file.
Could you change the opset version into 10 to see if it works first?
