Error burning image on microSD with md5sum ok
I am trying several times to write image onto a SD
root@kali:~# unzip -p Downloads/nv-jetson-nano-sd-card-image-r32.2.1\(2\).zip | dd of=/dev/mmcblk1 bs=1M status=progress
error [Downloads/nv-jetson-nano-sd-card-image-r32.2.1(2).zip]:  missing 3098985657 bytes in zipfile
  (attempting to process anyway)
error [Downloads/nv-jetson-nano-sd-card-image-r32.2.1(2).zip]:  start of central directory not found;
  zipfile corrupt.
  (please check that you have transferred or created the zipfile in the
  appropriate BINARY mode and that you have compiled UnZip properly)
0+0 records in
0+0 records out
0 bytes copied, 0,0193161 s, 0,0 kB/s
root@kali:~# md5sum Downloads/nv-jetson-nano-sd-card-image-r32.2.1*
7b87e26d59c560ca18692a1ba282d842  Downloads/nv-jetson-nano-sd-card-image-r32.2.1(1).zip
7b87e26d59c560ca18692a1ba282d842  Downloads/nv-jetson-nano-sd-card-image-r32.2.1(2).zip
7b87e26d59c560ca18692a1ba282d842  Downloads/nv-jetson-nano-sd-card-image-r32.2.1.zip
only
7z x Downloads/nv-jetson-nano-sd-card-image-r32.2.1\(2\).zip -so| dd of=/dev/mmcblk1 bs=1M status=progress
ERRORS:
Headers Error
Unavailable start of archive
12875857920 bytes (13 GB, 12 GiB) copied, 1769 s, 7,3 MB/s
1+276842 records in
1+276842 records out
12884901888 bytes (13 GB, 12 GiB) copied, 1771,85 s, 7,3 MB/s
seems working but with errors…
Hi n_lona, do you still get an error using the Etcher tool? https://www.balena.io/etcher/#download
7b87e26d59c560ca18692a1ba282d842 is the md5sum for me as well and it unzips fine with both unzip and 7zip.
Version of unzip is:
nZip 6.00 of 20 April 2009, by Debian. Original by Info-ZIP.
7z
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
Fwiw, md5 is not colission proof. It’s not hard to generate two completely different files that pass md5 verification. It protects against accidental corruption, but not intentional tampering. Of course it could just be a broken unzip program, which is why I posted the versions.
Etcher hangs always at 89%! Tried many times. Is the sd structure as follow:
Disk /dev/mmcblk1: 59,74 GiB, 64122519552 bytes, 125239296 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 457CDF32-009E-445C-B1A8-DFF5954FA326
Device          Start      End  Sectors  Size Type
/dev/mmcblk1p1  24576 25165790 25141215   12G Linux filesystem
/dev/mmcblk1p2   2048     2303      256  128K Linux filesystem
/dev/mmcblk1p3   4096     4991      896  448K Linux filesystem
/dev/mmcblk1p4   6144     7295     1152  576K Linux filesystem
/dev/mmcblk1p5   8192     8319      128   64K Linux filesystem
/dev/mmcblk1p6  10240    10623      384  192K Linux filesystem
/dev/mmcblk1p7  12288    13439     1152  576K Linux filesystem
/dev/mmcblk1p8  14336    14463      128   64K Linux filesystem
/dev/mmcblk1p9  16384    17663     1280  640K Linux filesystem
/dev/mmcblk1p10 18432    19327      896  448K Linux filesystem
/dev/mmcblk1p11 20480    20735      256  128K Linux filesystem
/dev/mmcblk1p12 22528    22687      160   80K Linux filesystem
Please confirm the structure of SD card.
