I’m new to Flex.
Flex does not require convex meshes for collisions, right?
(Flex is able to use triangle meshes directly)
I changed the command line option from’–physix’ to’–flex’ and ran my script(’ Reinforcement Learning Examples’), but I got the following error.
Could you give me some advice?
(rlgpu) @Fossa:~/wsp/isaacgym/python/rlgpu$ python train.py --task=FrankaCabinet --flex
Importing module ‘gym_37’ (/home/wsp/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_37.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/wsp/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
PyTorch version 1.8.1
Device count 1
/home/wsp/isaacgym/python/isaacgym/_bindings/src/gymtorch
Using /home/.cache/torch_extensions as PyTorch extensions root…
Emitting ninja build file /home/.cache/torch_extensions/gymtorch/build.ninja…
Building extension module gymtorch…
Allowing ninja to set a default number of workers… (overridable by setting the environment variable MAX_JOBS=N)
ninja: no work to do.
Loading extension module gymtorch…
Importing module ‘rlgpu_37’ (/home/wsp/isaacgym/python/isaacgym/_bindings/linux-x86_64/rlgpu_37.so)
WARNING: Using Flex with GPU instead of PHYSX!
Setting seed: 7581
Python
Physics Engine: FleX
Physics Device: cuda:0
GPU Pipeline: enabled
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
num franka bodies: 10
num franka dofs: 9
num cabinet bodies: 5
num cabinet dofs: 4
[Error] [carb.gym.plugin] Function fillActorRootStateTensor is not implemented
[Error] [carb.gym.plugin] Function fillDofStateTensor is not implemented
[Error] [carb.gym.plugin] Function setActorRootStateTensorIndexed is not implemented
[Error] [carb.gym.plugin] Function setDofPositionTargetTensorIndexed is not implemented
[Error] [carb.gym.plugin] Function setDofStateTensorIndexed is not implemented
Driver Version: 460.91.03 CUDA Version: 11.2
