Hey everyone, so I am playing around with object detection using the KITTI dataset and DetectNet. I am trying to use this for multi-class detection and keep receiving the error in the title of this post. My dataset is setup to resize images to 1280x720 with RGB as the Channel conversion. I ran across some tutorials for modifying the network to detect custom classes, specifically this one https://www.coria.com/insights/blog/computer-vision/training-a-custom-mutliclass-object-detection-model. After making the changes I am getting the above error and cannot seem to figure out why. Any insight would be great here is the log I am receiving:
bbox-obj-norm ← obj-block_obj-block_0_split_1
bbox-obj-norm → bboxes-obj-masked-norm
Setting up bbox-obj-norm
TEST Top shape for layer 171 ‘bbox-obj-norm’ 8 4 45 80 (115200)
Creating layer ‘bbox_loss’ of type ‘L1Loss’
Layer’s types are Ftype:FLOAT Btype:FLOAT Fmath:FLOAT Bmath:FLOAT
Created Layer bbox_loss (172)
bbox_loss ← bboxes-obj-masked-norm
bbox_loss ← bbox-obj-label-norm
bbox_loss → loss_bbox
Setting up bbox_loss
TEST Top shape for layer 172 ‘bbox_loss’ (1)
with loss weight 2
Creating layer ‘coverage_loss’ of type ‘EuclideanLoss’
Created Layer coverage_loss (173)
coverage_loss ← coverage_coverage/sig_0_split_0
coverage_loss ← coverage-label_slice-label_4_split_0
coverage_loss → loss_coverage
Check failed: bottom[0]->count(1) == bottom[1]->count(1) (21600 vs. 7200) Inputs must have the same dimension.
And here is my network configuration:
DetectNet network
Data/Input layers
layer {
type: “Data”
top: “data”
data_param {
backend: LMDB
source: “examples/kitti/kitti_train_images.lmdb”
batch_size: 10
include: { phase: TRAIN }
layer {
type: “Data”
top: “label”
data_param {
backend: LMDB
source: “examples/kitti/kitti_train_labels.lmdb”
batch_size: 10
layer {
type: “Data”
top: “data”
data_param {
backend: LMDB
source: “examples/kitti/kitti_test_images.lmdb”
batch_size: 6
include: { phase: TEST stage: “val” }
layer {
type: “Data”
top: “label”
data_param {
backend: LMDB
source: “examples/kitti/kitti_test_labels.lmdb”
batch_size: 6
layer {
type: “Input”
top: “data”
input_param {
shape {
dim: 1
dim: 3
dim: 720
dim: 1280
include: { phase: TEST not_stage: “val” }
Data transformation layers
layer {
type: “DetectNetTransformation”
bottom: “data”
bottom: “label”
top: “transformed_data”
top: “transformed_label”
detectnet_groundtruth_param: {
stride: 16
scale_cvg: 0.4
gridbox_type: GRIDBOX_MIN
coverage_type: RECTANGULAR
min_cvg_len: 20
obj_norm: true
image_size_x: 1280
image_size_y: 720
crop_bboxes: true
object_class: { src: 1 dst: 0} # car → 0
object_class: { src: 2 dst: 1} # van → 1
object_class: { src: 3 dst: 2} # truck → 2
object_class: { src: 4 dst: 3} # pedestrian → 3
object_class: { src: 5 dst: 4} # cyclist → 4
object_class: { src: 6 dst: 5} # tram → 5
detectnet_augmentation_param: {
crop_prob: 1
shift_x: 32
shift_y: 32
flip_prob: 0.5
rotation_prob: 0
max_rotate_degree: 5
scale_prob: 0.4
scale_min: 0.8
scale_max: 1.2
hue_rotation_prob: 0.8
hue_rotation: 30
desaturation_prob: 0.8
desaturation_max: 0.8
transform_param: {
mean_value: 127
layer {
bottom: “data”
bottom: “label”
stride: 16
scale_cvg: 0.4
min_cvg_len: 20
obj_norm: true
image_size_x: 1280
image_size_y: 720
crop_bboxes: false
object_class: { src: 1 dst: 0} # cars → 0
object_class: { src: 8 dst: 1} # pedestrians → 1
transform_param: {
mean_value: 127
layer {
type: “Power”
bottom: “data”
power_param {
shift: -127
Label conversion layers
layer {
type: “Slice”
bottom: “transformed_label”
top: “foreground-label”
top: “bbox-label”
top: “size-label”
top: “obj-label”
top: “coverage-label”
slice_param {
slice_dim: 1
slice_point: 1
slice_point: 5
slice_point: 7
slice_point: 8
include { phase: TRAIN }
include { phase: TEST stage: “val” }
layer {
type: “Concat”
bottom: “foreground-label”
top: “coverage-block”
concat_param {
concat_dim: 1
layer {
type: “Concat”
bottom: “size-label”
top: “size-block”
concat_param {
concat_dim: 1
layer {
type: “Concat”
bottom: “obj-label”
bottom: “obj-label”
bottom: “obj-label”
bottom: “obj-label”
top: “obj-block”
concat_param {
concat_dim: 1
layer {
type: “Eltwise”
bottom: “bbox-label”
bottom: “size-block”
top: “bbox-label-norm”
eltwise_param {
operation: PROD
layer {
type: “Eltwise”
bottom: “bbox-label-norm”
bottom: “obj-block”
top: “bbox-obj-label-norm”
eltwise_param {
operation: PROD
Start of convolutional network
layer {
type: “Convolution”
bottom: “transformed_data”
top: “conv1/7x7_s2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 3
kernel_size: 7
stride: 2
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “conv1/7x7_s2”
top: “conv1/7x7_s2”
layer {
type: “Pooling”
top: “pool1/3x3_s2”
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: “LRN”
bottom: “pool1/3x3_s2”
top: “pool1/norm1”
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: “Convolution”
bottom: “pool1/norm1”
top: “conv2/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “conv2/3x3_reduce”
layer {
type: “Convolution”
top: “conv2/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “conv2/3x3”
top: “conv2/3x3”
layer {
type: “LRN”
bottom: “conv2/3x3”
top: “conv2/norm2”
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: “Pooling”
bottom: “conv2/norm2”
top: “pool2/3x3_s2”
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: “Convolution”
bottom: “pool2/3x3_s2”
top: “inception_3a/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/1x1”
layer {
type: “Convolution”
top: “inception_3a/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/3x3_reduce”
layer {
type: “Convolution”
top: “inception_3a/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/3x3”
layer {
type: “Convolution”
top: “inception_3a/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/5x5_reduce”
layer {
type: “Convolution”
top: “inception_3a/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/5x5”
layer {
type: “Pooling”
top: “inception_3a/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_3a/pool”
top: “inception_3a/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3a/pool_proj”
layer {
type: “Concat”
top: “inception_3a/output”
layer {
type: “Convolution”
bottom: “inception_3a/output”
top: “inception_3b/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/1x1”
layer {
type: “Convolution”
top: “inception_3b/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/3x3_reduce”
layer {
type: “Convolution”
top: “inception_3b/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/3x3”
layer {
type: “Convolution”
top: “inception_3b/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/5x5_reduce”
layer {
type: “Convolution”
top: “inception_3b/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/5x5”
layer {
type: “Pooling”
top: “inception_3b/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_3b/pool”
top: “inception_3b/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_3b/pool_proj”
layer {
type: “Concat”
top: “inception_3b/output”
layer {
type: “Pooling”
bottom: “inception_3b/output”
top: “pool3/3x3_s2”
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: “Convolution”
bottom: “pool3/3x3_s2”
top: “inception_4a/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/1x1”
layer {
type: “Convolution”
top: “inception_4a/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 96
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/3x3_reduce”
layer {
type: “Convolution”
top: “inception_4a/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 208
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/3x3”
layer {
type: “Convolution”
top: “inception_4a/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/5x5_reduce”
layer {
type: “Convolution”
top: “inception_4a/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/5x5”
layer {
type: “Pooling”
top: “inception_4a/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_4a/pool”
top: “inception_4a/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4a/pool_proj”
layer {
type: “Concat”
top: “inception_4a/output”
layer {
type: “Convolution”
bottom: “inception_4a/output”
top: “inception_4b/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/1x1”
layer {
type: “Convolution”
top: “inception_4b/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/3x3_reduce”
layer {
type: “Convolution”
top: “inception_4b/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 224
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/3x3”
layer {
type: “Convolution”
top: “inception_4b/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/5x5_reduce”
layer {
type: “Convolution”
top: “inception_4b/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/5x5”
layer {
type: “Pooling”
top: “inception_4b/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_4b/pool”
top: “inception_4b/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4b/pool_proj”
layer {
type: “Concat”
top: “inception_4b/output”
layer {
type: “Convolution”
bottom: “inception_4b/output”
top: “inception_4c/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/1x1”
layer {
type: “Convolution”
top: “inception_4c/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/3x3_reduce”
layer {
type: “Convolution”
top: “inception_4c/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/3x3”
layer {
type: “Convolution”
top: “inception_4c/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/5x5_reduce”
layer {
type: “Convolution”
top: “inception_4c/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/5x5”
layer {
type: “Pooling”
top: “inception_4c/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_4c/pool”
top: “inception_4c/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4c/pool_proj”
layer {
type: “Concat”
top: “inception_4c/output”
layer {
type: “Convolution”
bottom: “inception_4c/output”
top: “inception_4d/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 112
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/1x1”
layer {
type: “Convolution”
top: “inception_4d/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 144
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/3x3_reduce”
layer {
type: “Convolution”
top: “inception_4d/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 288
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/3x3”
layer {
type: “Convolution”
top: “inception_4d/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/5x5_reduce”
layer {
type: “Convolution”
top: “inception_4d/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/5x5”
layer {
type: “Pooling”
top: “inception_4d/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_4d/pool”
top: “inception_4d/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4d/pool_proj”
layer {
type: “Concat”
top: “inception_4d/output”
layer {
type: “Convolution”
bottom: “inception_4d/output”
top: “inception_4e/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/1x1”
layer {
type: “Convolution”
top: “inception_4e/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/3x3_reduce”
layer {
type: “Convolution”
top: “inception_4e/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/3x3”
layer {
type: “Convolution”
top: “inception_4e/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/5x5_reduce”
layer {
type: “Convolution”
top: “inception_4e/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/5x5”
layer {
type: “Pooling”
top: “inception_4e/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_4e/pool”
top: “inception_4e/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_4e/pool_proj”
layer {
type: “Concat”
top: “inception_4e/output”
layer {
type: “Convolution”
bottom: “inception_4e/output”
top: “inception_5a/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 256
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/1x1”
layer {
type: “Convolution”
top: “inception_5a/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 160
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.09
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/3x3_reduce”
layer {
type: “Convolution”
top: “inception_5a/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 320
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/3x3”
layer {
type: “Convolution”
top: “inception_5a/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.2
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/5x5_reduce”
layer {
type: “Convolution”
top: “inception_5a/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/5x5”
layer {
type: “Pooling”
top: “inception_5a/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_5a/pool”
top: “inception_5a/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5a/pool_proj”
layer {
type: “Concat”
top: “inception_5a/output”
layer {
type: “Convolution”
bottom: “inception_5a/output”
top: “inception_5b/1x1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/1x1”
layer {
type: “Convolution”
top: “inception_5b/3x3_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
convolution_param {
num_output: 192
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/3x3_reduce”
layer {
type: “Convolution”
top: “inception_5b/3x3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/3x3”
layer {
type: “Convolution”
top: “inception_5b/5x5_reduce”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/5x5_reduce”
layer {
type: “Convolution”
top: “inception_5b/5x5”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
pad: 2
kernel_size: 5
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/5x5”
layer {
type: “Pooling”
top: “inception_5b/pool”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “inception_5b/pool”
top: “inception_5b/pool_proj”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 128
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.1
bias_filler {
type: “constant”
value: 0.2
layer {
type: “ReLU”
bottom: “inception_5b/pool_proj”
layer {
type: “Concat”
top: “inception_5b/output”
layer {
type: “Dropout”
bottom: “inception_5b/output”
top: “pool5/drop_s1”
dropout_param {
dropout_ratio: 0.4
layer {
type: “Convolution”
bottom: “pool5/drop_s1”
top: “cvg/classifier”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 6
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.
layer {
type: “Sigmoid”
bottom: “cvg/classifier”
top: “coverage”
layer {
type: “Convolution”
top: “bboxes”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 4
kernel_size: 1
weight_filler {
type: “xavier”
std: 0.03
bias_filler {
type: “constant”
value: 0.
End of convolutional network
Convert bboxes
layer {
type: “Eltwise”
bottom: “bboxes”
bottom: “coverage-block”
top: “bboxes-masked”
eltwise_param {
operation: PROD
layer {
type: “Eltwise”
bottom: “bboxes-masked”
top: “bboxes-masked-norm”
eltwise_param {
operation: PROD
layer {
type: “Eltwise”
bottom: “bboxes-masked-norm”
bottom: “obj-block”
top: “bboxes-obj-masked-norm”
eltwise_param {
operation: PROD
Loss layers
layer {
type: “L1Loss”
bottom: “bboxes-obj-masked-norm”
bottom: “bbox-obj-label-norm”
top: “loss_bbox”
loss_weight: 2
layer {
type: “EuclideanLoss”
bottom: “coverage”
bottom: “coverage-label”
top: “loss_coverage”
Cluster bboxes
layer {
type: ‘Python’
bottom: ‘coverage’
bottom: ‘bboxes’
top: ‘bbox-list-class0’
top: ‘bbox-list-class1’
top: ‘bbox-list-class2’
top: ‘bbox-list-class3’
top: ‘bbox-list-class4’
top: ‘bbox-list-class5’
python_param {
module: ‘caffe.layers.detectnet.clustering’
layer: ‘ClusterDetections’
param_str : ‘1280, 720, 16, 0.6, 3, 0.02, 22, 6’
include: { phase: TEST }
Calculate mean average precision
layer {
type: ‘Python’
bottom: ‘coverage-label’
bottom: ‘bbox-label’
top: ‘bbox-list-label-class0’
top: ‘bbox-list-label-class1’
top: ‘bbox-list-label-class2’
top: ‘bbox-list-label-class3’
top: ‘bbox-list-label-class4’
top: ‘bbox-list-label-class5’
python_param {
layer: ‘ClusterGroundtruth’
param_str : ‘1280, 720, 16, 6’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class0’
bottom: ‘bbox-list-class0’
top: ‘bbox-list-scored-class0’
python_param {
module: ‘caffe.layers.detectnet.mean_ap’
layer: ‘ScoreDetections’
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class0’
top: ‘mAP-class0’
top: ‘precision-class0’
top: ‘recall-class0’
python_param {
layer: ‘mAP’
param_str : ‘1280, 720, 16’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class1’
bottom: ‘bbox-list-class1’
top: ‘bbox-list-scored-class1’
python_param {
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class1’
top: ‘mAP-class1’
top: ‘precision-class1’
top: ‘recall-class1’
python_param {
layer: ‘mAP’
param_str : ‘1248, 352, 16’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class2’
bottom: ‘bbox-list-class2’
top: ‘bbox-list-scored-class2’
python_param {
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class2’
top: ‘mAP-class2’
top: ‘precision-class2’
top: ‘recall-class2’
python_param {
layer: ‘mAP’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class3’
bottom: ‘bbox-list-class3’
top: ‘bbox-list-scored-class3’
python_param {
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class3’
top: ‘mAP-class3’
top: ‘precision-class3’
top: ‘recall-class3’
python_param {
layer: ‘mAP’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class4’
bottom: ‘bbox-list-class4’
top: ‘bbox-list-scored-class4’
python_param {
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class4’
top: ‘mAP-class4’
top: ‘precision-class4’
top: ‘recall-class4’
python_param {
layer: ‘mAP’
layer {
type: ‘Python’
bottom: ‘bbox-list-label-class5’
bottom: ‘bbox-list-class5’
top: ‘bbox-list-scored-class5’
python_param {
layer {
type: ‘Python’
bottom: ‘bbox-list-scored-class5’
top: ‘mAP-class5’
top: ‘precision-class5’
top: ‘recall-class5’
python_param {
layer: ‘mAP’
