Error checking disk space
We are doing the system image of mass production, and then the following errors occur when checking the disk. We don’t know whether there are security risks of system stability in the later stage.
Image_20210914102202
hello 2415448472,
could you please execute $ sudo fdisk -l
and, please share the results for reference,
thanks
root@nvidia-desktop:~# fdisk -l
Disk /dev/ram0: 8 MiB, 8388608 bytes, 16384 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram2: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram3: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram4: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram5: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram6: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram7: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram8: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram9: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram10: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram11: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram12: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram13: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram14: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/ram15: 8 MiB, 8388608 bytes, 16384 sectors
Disk /dev/loop0: 16 MiB, 16777216 bytes, 32768 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Disk /dev/mmcblk0: 14.7 GiB, 15758000128 bytes, 30777344 sectors
Disklabel type: gpt
Disk identifier: 2F789E73-D049-4E3F-B082-0D21F0F6A551
Device             Start      End  Sectors   Size Type
/dev/mmcblk0p1        34 29360161 29360128    14G Microsoft basic data
/dev/mmcblk0p2  29360162 29362209     2048     1M Microsoft basic data
/dev/mmcblk0p3  29362210 29374497    12288     6M Microsoft basic data
/dev/mmcblk0p4  29374498 29374657      160    80K Microsoft basic data
/dev/mmcblk0p5  29374658 29505697   131040    64M Microsoft basic data
/dev/mmcblk0p6  29505698 29507745     2048     1M Microsoft basic data
/dev/mmcblk0p7  29507746 29520033    12288     6M Microsoft basic data
/dev/mmcblk0p8  29520034 29520193      160    80K Microsoft basic data
/dev/mmcblk0p9  29520194 29651233   131040    64M Microsoft basic data
/dev/mmcblk0p10 29651234 29651617      384   192K Microsoft basic data
/dev/mmcblk0p11 29651618 29652129      512   256K Microsoft basic data
/dev/mmcblk0p12 29652130 29781153   129024    63M Microsoft basic data
/dev/mmcblk0p13 29781154 29782177     1024   512K Microsoft basic data
/dev/mmcblk0p14 29782178 29782689      512   256K Microsoft basic data
/dev/mmcblk0p15 29782690 29783201      512   256K Microsoft basic data
/dev/mmcblk0p16 29783202 30397601   614400   300M Microsoft basic data
/dev/mmcblk0p17 30397602 30777310   379709 185.4M Microsoft basic data
Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1: 119.3 GiB, 128043712512 bytes, 250085376 sectors
Disklabel type: dos
Device         Boot Start       End   Sectors   Size Id Type
/dev/mmcblk1p1       2048 250085375 250083328 119.3G 83 Linux
Disk /dev/zram0: 495.5 MiB, 519589888 bytes, 126853 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 495.5 MiB, 519589888 bytes, 126853 sectors
Disk /dev/zram2: 495.5 MiB, 519589888 bytes, 126853 sectors
Disk /dev/zram3: 495.5 MiB, 519589888 bytes, 126853 sectors
hello 2415448472,
may I also know which JetPack release you’re working with, $ cat /etc/nv_tegra_release
also, did you program the fuse the enable Jetson security.
We use jetpack4.4.1
We didn’t notice , how the fuse was programmed to enable Jetson security.
hello 2415448472,
I’m just double confirmation, it’s unnecessary to program the fuse.
such failure: Warning: Error fsyncing/closing... , it looks like partition damaged.
are you able to format the disk completely for confirmation?
