Hello Arturo,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, this error message you are getting when the driver is not loaded/ or properly loaded.
See below example output based on a node running FreeBSD w/ ConnectX-6 configured in Ethernet mode.
With driver loaded:
mlxreg -d mst status | awk '{print$1}' | tail -n +3 --reg_name ROCE_ACCL --get
Sending access register…
Field Name | Data
roce_adp_retrans_field_select | 0x00000001
roce_tx_window_field_select | 0x00000001
roce_slow_restart_field_select | 0x00000001
roce_slow_restart_idle_field_select | 0x00000001
roce_adp_retrans_en | 0x00000000
roce_tx_window_en | 0x00000000
roce_slow_restart_en | 0x00000000
roce_slow_restart_idle_en | 0x00000000
Example output with driver unloaded:
kldunload mlx5en
kldunload mlx5ib
kldstat
Id Refs Address Size Name
1 28 0xffffffff80200000 227b0a0 kernel
3 1 0xffffffff824b7000 63fd0 mlx5.ko
4 2 0xffffffff8251b000 39a8 mlxfw.ko
5 2 0xffffffff8251f000 4790 xz.ko
6 4 0xffffffff82524000 2da38 linuxkpi.ko
7 1 0xffffffff82552000 3b98 dcons.ko
9 1 0xffffffff8258b000 a3538 ibcore.ko
10 1 0xffffffff82912000 1a20 fdescfs.ko
11 1 0xffffffff82914000 2698 intpm.ko
12 1 0xffffffff82917000 b40 smbus.ko
13 1 0xffffffff82918000 1860 uhid.ko
14 1 0xffffffff8291a000 2908 ums.ko
15 1 0xffffffff8291d000 46f0 autofs.ko
kldunload mlx5
-E- Failed to send access register: ME_ICMD_OPERATIONAL_ERROR
With driver loaded, and Enabling Lossy RoCE accelerations:
kldload mlx5 mlkx5ib mlx5en && /etc/netstart
mlxreg -d mst status | awk '{print$1}' | tail -n +3 --reg_name ROCE_ACCL --set “roce_adp_retrans_en=0x1,roce_tx_window_en=0x1,roce_slow_restart_en=0x1”
You are about to send access register: ROCE_ACCL with the following data:
Field Name | Data
roce_adp_retrans_en | 0x00000001
roce_tx_window_en | 0x00000001
roce_slow_restart_en | 0x00000001
Do you want to continue ? (y/n) [n] :
Also make sure the adapter is configured for Ethernet.
Instructions work as well when running Linux, just make sure that the driver is loaded properly.
Thank you and regards,
~NVIDIA Networking Technical Support
