I modified nvresizefs.sh
with the changes described in the link below:
This issue would still need this patch on rel-35.1 GA to get fully fixed.
diff --git a/rfs/usr/lib/nvidia/resizefs/nvresizefs.sh b/rfs/usr/lib/nvidia/resizefs/nvresizefs.sh
index 37d3ad3..cd36266 100755
--- a/rfs/usr/lib/nvidia/resizefs/nvresizefs.sh
+++ b/rfs/usr/lib/nvidia/resizefs/nvresizefs.sh
@@ -1,6 +1,6 @@
#!/bin/bash
-# Copyright (c) 2019-2021, NVIDIA CORPORATION. All rights reserved.
+# Copyright (c) 2019-2022, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in…
Also modified flash_t234_qspi_sdmmc.xml
with the changes described below:
Please try to modify allocation_attribute of APP from 0x8 to 0x808:
Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml
<partition name="APP" id="1" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> APPSIZE </size>
<file_system_attribute> 0 </file_system_attribute>
- <allocation_attribute> 0x8 </allocation_attribute>
+ <allocation_attribute> 0x808 </allocation_attribute>
And flash again with -r p…
My files: flash_t234_qspi_sdmmc.xml (35.6 KB)
nvresizefs.sh (6.4 KB)
I get the same result when creating the clone. The size of the image is 0 bytes
Solution:
Use the clone.img.raw to flash the target device.
sudo cp clone.img.raw bootloader/system.img
sudo ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1
After modifying the files mentioned above and using clone.img.raw, I was able to succesfully clone and flash Jetson Orin AGX
Orin AGX, my bad. I made a mistake when creating the topic.
