Error Code 1: Cuda Runtime (invalid argument)
Description
When I use pyCUDA and TensorRT inference, the code will report the following error at the end of execution
Environment
TensorRT Version: 8.5.3.1
GPU Type: RTX3060
Nvidia Driver Version:
CUDA Version: 11.6 – 11.6.0_511.23
CUDNN Version: 8.9.5.30
Operating System + Version: Windows 11 Professional
Python Version (if applicable): 3.8.5
TensorFlow Version (if applicable): not installed
PyTorch Version (if applicable): torch-1.13.1+cu116-cp38-cp38-win_amd64
Baremetal or Container (if container which image + tag): No
Relevant Files
src code:
import warnings
warnings.filterwarnings("ignore")
import ctypes
import os
import numpy as np
import cv2
import random
import tensorrt as trt
import pycuda.autoinit
import pycuda.driver as cuda
import torch
import math
from torchvision.ops import roi_align
import argparse
import os
import platform
import shutil
import time
from pathlib import Path
import sys
import json
import cv2
import torch
import numpy as np
import argparse
import time
import cv2
from ultralytics import YOLO
class TrtInference():
    _batch_size = 1
    def __init__(self, model_path=None):
        self._model_path = model_path
        if self._model_path is None:
            print("please set trt model path!")
            exit()
        self.cuda_ctx = cuda.Device(0).make_context()
        #self.stream = cuda.Stream()
        TRT_LOGGER = trt.Logger(trt.Logger.INFO)
        trt.init_libnvinfer_plugins(TRT_LOGGER, '')
        runtime = trt.Runtime(TRT_LOGGER)
        # deserialize engine
        with open(self._model_path, 'rb') as f:
            buf = f.read()
            self.engine = runtime.deserialize_cuda_engine(buf)
        #self.context = self.engine.create_execution_context()
        for index, binding in enumerate(self.engine):
            if self.engine.binding_is_input(binding):
                batch_shape = list(self.engine.get_binding_shape(binding)).copy()
                batch_shape[0] = self._batch_size
                #self.context.set_binding_shape(index, batch_shape)
        self.host_inputs, self.host_outputs, self.cuda_inputs, self.cuda_outputs, self.bindings = self._allocate_buffers()
    def _allocate_buffers(self):
        host_inputs, host_outputs, cuda_inputs, cuda_outputs, bindings = \
            # size = trt.volume(self.context.get_binding_shape(index)) * \
            #        self.engine.max_batch_size
            size = trt.volume(self.engine.get_tensor_shape(binding)) * self.engine.max_batch_size
            host_mem = cuda.pagelocked_empty(size, np.float32)
            cuda_mem = cuda.mem_alloc(host_mem.nbytes)
            bindings.append(int(cuda_mem))
                host_inputs.append(host_mem)
                cuda_inputs.append(cuda_mem)
            else:
                host_outputs.append(host_mem)
                cuda_outputs.append(cuda_mem)
        return host_inputs, host_outputs, cuda_inputs, cuda_outputs, bindings
    #def destroy(self):
    def __del__(self):
        """Free CUDA memories and context."""
        print('---del func---')
        del self.host_inputs
        del self.host_outputs
        del self.cuda_inputs
        del self.cuda_outputs
        del self.bindings
        del self.engine
        #del self.stream
        self.cuda_ctx.pop()
        del self.cuda_ctx
        #print(self.cuda_ctx.detach())
        #pycuda.tools.clear_context_caches()
        #cuda.DeviceAllocation.free()
    def inference(self, inputs):
        self.cuda_ctx.push()
        try:
            np.copyto(self.host_inputs[0], inputs[0].ravel())
            np.copyto(self.host_inputs[1], inputs[1].ravel())
            np.copyto(self.host_inputs[2], inputs[2].ravel())
        except:
            return None
        # cuda.memcpy_htod_async(
        #     self.cuda_inputs[0], self.host_inputs[0], stream)
        #     self.cuda_inputs[1], self.host_inputs[1], stream)
        #     self.cuda_inputs[2], self.host_inputs[2], stream)
        # self.context.execute_async(
        #     batch_size=1,
        #     bindings=self.bindings,
        #     stream_handle=stream.handle)
        context.execute_v2(
            self.bindings)
        cuda.memcpy_dtoh_async(
            self.host_outputs[0], self.cuda_outputs[0], stream)
        stream.synchronize()
        self.cuda_ctx.pop()
        output = np.reshape(self.host_outputs[0],(32,15))
        return output
class ActionPredict:
    def __init__(self,slowfast_model_path='',yolo_model_path='',
                 slowfast_label_path=''):
        self.slowfast_model_path = slowfast_model_path
        self.yolo_model_path = yolo_model_path
        self.slowfast_label_path = slowfast_label_path
        self.action = ''
        self.name_list = []
        self.box_list = []
        self.action_names = self.get_class_names(self.slowfast_label_path)
        self.yolo_model = YOLO(self.yolo_model_path,task='detect')
        self.slowfast = TrtInference(self.slowfast_model_path)
    def runActionPred(self,frames):
        name_list, rect_list = self.run_object_detection(frames)
        action = self.run_action_detection(frames,self.action_names)
        self.action = action
        self.box_list = rect_list
        self.name_list = name_list
    def get_action_preds(self):
        return self.action
    def get_name_list(self):
        return self.name_list
    def get_box_list(self):
        return self.box_list
    def detect_objects_single(self,yolo_model,frame):
        tensor_bboxs = []
        result_list = []
        #------只检测中间帧-------#
        results = yolo_model(frame,conf=0.5,task='detect',verbose=False)
        #-----------动作识别使用-----------#
        boxes = results[0].boxes
        mask = boxes.cls == 2 #对应person的label序号
        pred_boxes = boxes.xyxy[mask]
        if(len(pred_boxes.tolist()) > 0):
            tensor_bboxs.append(pred_boxes)#动作识别使用
        find_person = False
        for result in results:
            if find_person:
                break
            for box in result.boxes:
                text_name = f"{result.names[int(box.cls[0])]}"
                #print(text_name)
                if text_name != 'person':
                    continue
                find_person = True
                #rect = (float(box.xyxy[0][0]), float(box.xyxy[0][1]),float(box.xyxy[0][2]), float(box.xyxy[0][3]))
                result_list.append([float(box.xyxy[0][0]),float(box.xyxy[0][1]),float(box.xyxy[0][2]),float(box.xyxy[0][3])])
                break
        if len(result_list)==0:
            for i in range(32-len(result_list)):
                result_list.append([float(0),float(0),float(0),float(0)])
        else:
            for i in range(1,32):
                result_list.append(result_list[0])
        return torch.from_numpy(np.array(result_list))
    def run_object_detection(self,frames):
        tensor_bboxs = []
        name_list = []
        box_list = []
        for frame in frames:
            results = self.yolo_model(frame,conf=0.5,task='detect',verbose=False)
            label_list = []
            rect_list = []
                    rect = (int(box.xyxy[0][0]), int(box.xyxy[0][1]),int(box.xyxy[0][2]), int(box.xyxy[0][3]))
                    label_list.append(text_name)
                    rect_list.append(rect)
            name_list.append(label_list)
            box_list.append(rect_list)
        return name_list,box_list
    def run_action_detection(self,frames,classes):
        action = ''
        bboxes =  self.detect_objects_single(self.yolo_model,frames[15])
        if bboxes is not None:
            frames = [cv2.cvtColor(frame, cv2.COLOR_BGR2RGB) for frame in frames]
            frames = [self.scale(256, frame) for frame in frames]
            inputs = self.process_cv2_inputs(frames)
                bboxes = self.scale_boxes(256,bboxes,1080,1920)
                index_pad = torch.full(
                    size=(bboxes.shape[0], 1),
                    fill_value=float(0),
                    device=bboxes.device,
                # Pad frame index for each box.
                bboxes = torch.cat([index_pad, bboxes], axis=1)
            #print('------------1-----------')
            for i in range(len(inputs)):
                inputs[i] = inputs[i].numpy()
                #print(inputs[i])
            #print('------------2-----------')
                inputs.append(bboxes.numpy().astype(np.float32))
                outputs=self.slowfast.inference(inputs)
                if outputs is None:
                    return ''
                list_out = list(outputs[0])
                index_of_max = list_out.index(max(list_out))
                name = classes[index_of_max]
                score = list_out[index_of_max]
                #print(name + ': ' + str(score))
                str_score = '%0.2f'%score
                action = name + ': ' + str_score
                #print('-----------outputs[0]------------')
                #print(outputs)
        else:
            action = ''
        return action
    def scale(self,size, image):
        Scale the short side of the image to size.
        Args:
            size (int): size to scale the image.
            image (array): image to perform short side scale. Dimension is
                `height` x `width` x `channel`.
        Returns:
            (ndarray): the scaled image with dimension of
        height = image.shape[0]
        width = image.shape[1]
        # print(height,width)
        if (width <= height and width == size) or (
            height <= width and height == size
            return image
        new_width = size
        new_height = size
        if width < height:
            new_height = int(math.floor((float(height) / width) * size))
        else:
            new_width = int(math.floor((float(width) / height) * size))
        img = cv2.resize(
            image, (new_width, new_height), interpolation=cv2.INTER_LINEAR
        # print(new_width, new_height)
        return img.astype(np.float32)
    def tensor_normalize(self,tensor, mean, std, func=None):
        Normalize a given tensor by subtracting the mean and dividing the std.
        Args:
            tensor (tensor): tensor to normalize.
            mean (tensor or list): mean value to subtract.
            std (tensor or list): std to divide.
        if tensor.dtype == torch.uint8:
            tensor = tensor.float()
            tensor = tensor / 255.0
        if type(mean) == list:
            mean = torch.tensor(mean)
        if type(std) == list:
            std = torch.tensor(std)
        if func is not None:
            tensor = func(tensor)
        tensor = tensor - mean
        tensor = tensor / std
        return tensor
    def scale_boxes(self,size, boxes, height, width):
        Scale the short side of the box to size.
        Args:
            boxes (ndarray): bounding boxes to peform scale. The dimension is
            `num boxes` x 4.
            height (int): the height of the image.
            width (int): the width of the image.
        Returns:
            boxes (ndarray): scaled bounding boxes.
            return boxes
        new_width = size
        new_height = size
        if width < height:
            boxes *= float(new_height) / height
        else:
            boxes *= float(new_width) / width
        return boxes
    def process_cv2_inputs(self,frames):
        Normalize and prepare inputs as a list of tensors. Each tensor
        correspond to a unique pathway.
        Args:
            frames (list of array): list of input images (correspond to one clip) in range [0, 255].
            cfg (CfgNode): configs. Details can be found in
                slowfast/config/defaults.py
        inputs = torch.from_numpy(np.array(frames)).float() / 255
        inputs = self.tensor_normalize(inputs, [0.45,0.45,0.45], [0.225,0.225,0.225])
        # T H W C -> C T H W.
        inputs = inputs.permute(3, 0, 1, 2)
        # Sample frames for num_frames specified.
        index = torch.linspace(0, inputs.shape[1] - 1, 32).long()
        #print(index)
        inputs = torch.index_select(inputs, 1, index)
        fast_pathway = inputs
        slow_pathway = torch.index_select(
                inputs,
                1,
                torch.linspace(
                    0, inputs.shape[1] - 1, inputs.shape[1] // 4
                ).long(),
        frame_list = [slow_pathway, fast_pathway]
        #print(np.shape(frame_list[0]))
        inputs = [inp.unsqueeze(0) for inp in frame_list]
        return inputs
    def get_class_names(self,label_path):
        name_list = []
        with open(label_path, 'r') as file:
            line = file.readline()
            while line:
                #print(line.strip())  # 去掉尾部的换行符
                name = line.strip()
                name_list.append(name)
        return name_list
def create_video_writer(video_cap, output_filename):
    # grab the width, height, and fps of the frames in the video stream.
    frame_width = int(video_cap.get(cv2.CAP_PROP_FRAME_WIDTH))
    frame_height = int(video_cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
    fps = int(video_cap.get(cv2.CAP_PROP_FPS))
    # initialize the FourCC and a video writer object
    fourcc = cv2.VideoWriter_fourcc(*'MP4V')
    writer = cv2.VideoWriter(output_filename, fourcc, fps,
                             (frame_width, frame_height))
    return writer
if __name__ == "__main__":
    slowfast_model_path = 'action.engine'
    slowfast_label_path = 'action.txt'
    yolo_model_path = 'object.engine'
    cap = cv2.VideoCapture('./test.mp4')
    #cap = cv2.VideoCapture('rtmp://10.17.170.64/live/')
    print(cap.isOpened())
    frame_list = []
    #output_filename = "out.mp4"
    #writer = create_video_writer(cap, output_filename)
    predictor = ActionPredict(slowfast_model_path,yolo_model_path,slowfast_label_path)
    count = 0
    while True:
        _,frame = cap.read()
        if frame is None:
            break
        frame_list.append(frame)
        if len(frame_list) == 32:
            start = cv2.getTickCount()
            predictor.runActionPred(frame_list)
            action = predictor.get_action_preds()
            name_list = predictor.get_name_list()
            box_list = predictor.get_box_list()
            # 记录结束时间
            end = cv2.getTickCount()
            # 运行耗时
            use_time = (end - start) / cv2.getTickFrequency()
            print('use-time: %.4fs' % use_time)
            print(action)
            # LOGGER.info(name_list)
            # LOGGER.info(box_list)
            for i in range(len(frame_list)):
                img = frame_list[i]
                for j in range(0,len(name_list[i])):
                    name = name_list[i][j]
                    x1 = box_list[i][j][0]
                    y1 = box_list[i][j][1]
                    x2 = box_list[i][j][2]
                    y2 = box_list[i][j][3]
                    cv2.rectangle(img,(x1,y1),(x2,y2),(255,0,255),2, cv2.LINE_AA)
                    cv2.putText(img,name,(x1,y1+30),0,1.5,(255,255,0),2)
                    if name == 'person':
                        cv2.putText(img,action,(x1,y1-30),0,2.2,(0,255,0),3)
                #writer.write(img)
                showimg=cv2.resize(img,None,fx=0.5,fy=0.5,interpolation=cv2.INTER_LINEAR)
                cv2.imshow('img',showimg)
                cv2.waitKey(1)
            frame_list.clear()
            count += 1
            if count == 10:
               break
        else:
            continue
    cap.release()
    #writer.release()
    #predictor.slowfast.destroy()
    print('------OK------')
model files:
Steps To Reproduce
Please include:
step: run python test.py
full error message:
[09/12/2024-19:04:55] [TRT] [E] 1: [cudaResources.cpp::nvinfer1::ScopedCudaEvent::~ScopedCudaEvent::24] Error Code 1: Cuda Runtime (invalid device context)
[09/12/2024-19:04:55] [TRT] [E] 1: [defaultAllocator.cpp::nvinfer1::internal::DefaultAllocator::deallocate::42] Error Code 1: Cuda Runtime (invalid argument)
I have searched for many methods but have not been able to solve it. Please provide assistance. Thank you
Hi @3252314061
Di dyou try setting up TRT with teh installation doc steps?
this is a cuda issue, which may have come up because of the corrupted env likely.
