Error Code 1: Internal Error (Error: Weights of same values but of different types are used in the network!)
Description
I’m trying to convert a Pytorch model to onnx then convert it to a tensorRT engine using trtexec and got the following error
[E] Error[1]: [network.cpp::setWeightsName::3366] Error Code 1: Internal Error (Error: Weights of same values but of different types are used in the network!)
Here’s the full output:
[03/21/2023-07:32:23] [W] [TRT] onnx2trt_utils.cpp:375: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[03/21/2023-07:32:23] [W] [TRT] onnx2trt_utils.cpp:403: One or more weights outside the range of INT32 was clamped
[03/21/2023-07:32:26] [E] Error[1]: [network.cpp::setWeightsName::3366] Error Code 1: Internal Error (Error: Weights of same values but of different types are used in the network!)
[03/21/2023-07:32:26] [E] [TRT] ModelImporter.cpp:726: While parsing node number 1288 [ConstantOfShape -> "/anchor_generator/ConstantOfShape_output_0"]:
[03/21/2023-07:32:26] [E] [TRT] ModelImporter.cpp:727: --- Begin node ---
[03/21/2023-07:32:26] [E] [TRT] ModelImporter.cpp:728: input: "/anchor_generator/Constant_12_output_0"
output: "/anchor_generator/ConstantOfShape_output_0"
op_type: "ConstantOfShape"
attribute {
  t {
    dims: 1
    data_type: 7
    raw_data: "\000\000\000\000\000\000\000\000"
  type: TENSOR
[03/21/2023-07:32:26] [E] [TRT] ModelImporter.cpp:729: --- End node ---
[03/21/2023-07:32:26] [E] [TRT] ModelImporter.cpp:731: ERROR: ModelImporter.cpp:172 In function parseGraph:
[6] Invalid Node - /anchor_generator/ConstantOfShape
[03/21/2023-07:32:26] [E] Failed to parse onnx file
[03/21/2023-07:32:26] [E] Parsing model failed
[03/21/2023-07:32:26] [E] Failed to create engine from model or file.
[03/21/2023-07:32:26] [E] Engine set up failed
Environment
Device: Orin AGX
Dockerfile Content:
FROM nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel
RUN apt update
RUN apt --fix-broken install
RUN apt install -y mpich
RUN pip install mpi4py
RUN pip install torchinfo
RUN pip install clearml
RUN pip install segmentation-models-pytorch
RUN pip install transformers
RUN pip install nvidia-tao-deploy
Relevant Files
Link to .onnx file
Steps To Reproduce
Download the .onnx file & Run the command below in terminal
RetinaNet_(1, 3, 1080, 1440)_15.log (5.4 KB)
/usr/src/tensorrt/bin/trtexec --onnx='/workspaces/scratch_ai/onnx/RetinaNet_(1, 3, 1080, 1440)_15.onnx' --saveEngine='/workspaces/scratch_ai/trt/RetinaNet_(1, 3, 1080, 1440)_15.engine' --exportProfile='/workspaces/scratch_ai/trt/RetinaNet_(1, 3, 1080, 1440)_15.json' --allowGPUFallback --useSpinWait --separateProfileRun > '/workspaces/scratch_ai/trt/RetinaNet_(1, 3, 1080, 1440)_15.log'
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
The ONNX model is in the shared link. Can’t upload due to file size.
