Description
I’m using Amazon EC2 g5.8xlarge instance type & following below document and trying to deploy Meta-Llama-3-8B-Instruct model & triton inference server.
I also referred below compatibility matrix
https://docs.nvidia.com/deeplearning/triton-inference-server/user-guide/docs/introduction/compatibility.html
I’m using
Triton release version: 24.06
Python version: 3.10.12
TensorRT-LLM version: 0.10.0
CUDA version: 12.4.0.041
CUDA Driver version: 550.54.14
I used 0.10.0 branch for GitHub - triton-inference-server/tensorrtllm_backend: The Triton TensorRT-LLM Backend.
Used 0.10.0 version for tensorrt_llm pip package.
Upon executing last command of the document
python3 tensorrtllm_backend/scripts/launch_triton_server.py --model_repo tensorrtllm_backend/all_models/inflight_batcher_llm --world_size 1
I’m getting below error
I0206 15:23:04.598706 721 pinned_memory_manager.cc:277] “Pinned memory pool is created at ‘0x7fc780000000’ with size 268435456”
I0206 15:23:04.599117 721 cuda_memory_manager.cc:107] “CUDA memory pool is created on device 0 with size 67108864”
I0206 15:23:04.602520 721 model_lifecycle.cc:472] “loading: postprocessing:1”
I0206 15:23:04.602579 721 model_lifecycle.cc:472] “loading: preprocessing:1”
I0206 15:23:04.602641 721 model_lifecycle.cc:472] “loading: tensorrt_llm:1”
I0206 15:23:04.602685 721 model_lifecycle.cc:472] “loading: tensorrt_llm_bls:1”
I0206 15:23:04.679505 721 python_be.cc:1912] “TRITONBACKEND_ModelInstanceInitialize: preprocessing_0_0 (CPU device 0)”
I0206 15:23:04.679543 721 python_be.cc:1912] “TRITONBACKEND_ModelInstanceInitialize: postprocessing_0_0 (CPU device 0)”
I0206 15:23:04.728032 721 python_be.cc:1912] “TRITONBACKEND_ModelInstanceInitialize: tensorrt_llm_bls_0_0 (CPU device 0)”
[TensorRT-LLM][WARNING] gpu_device_ids is not specified, will be automatically set
[TensorRT-LLM][WARNING] iter_stats_max_iterations is not specified, will use default value of 1000
[TensorRT-LLM][WARNING] request_stats_max_iterations is not specified, will use default value of 0
[TensorRT-LLM][WARNING] normalize_log_probs is not specified, will be set to true
[TensorRT-LLM][WARNING] kv_cache_host_memory_bytes not set, defaulting to 0
[TensorRT-LLM][WARNING] kv_cache_onboard_blocks not set, defaulting to true
[TensorRT-LLM][WARNING] sink_token_length is not specified, will use default value
[TensorRT-LLM][WARNING] enable_chunked_context is not specified, will be set to false.
[TensorRT-LLM][WARNING] batch_scheduler_policy parameter was not found or is invalid (must be max_utilization or guaranteed_no_evict)
[TensorRT-LLM][WARNING] lora_cache_max_adapter_size not set, defaulting to 64
[TensorRT-LLM][WARNING] lora_cache_optimal_adapter_size not set, defaulting to 8
[TensorRT-LLM][WARNING] lora_cache_gpu_memory_fraction not set, defaulting to 0.05
[TensorRT-LLM][WARNING] lora_cache_host_memory_bytes not set, defaulting to 1GB
[TensorRT-LLM][WARNING] decoding_mode parameter is invalid or not specified(must be one of the {top_k, top_p, top_k_top_p, beam_search}).Using default: top_k_top_p if max_beam_width == 1, beam_search otherwise
[TensorRT-LLM][WARNING] medusa_choices parameter is not specified. Will be using default mc_sim_7b_63 choices instead
[TensorRT-LLM][WARNING] gpu_weights_percent parameter is not specified, will use default value of 1.0
[TensorRT-LLM][INFO] Engine version 0.10.0 found in the config file, assuming engine(s) built by new builder API.
[TensorRT-LLM][WARNING] [json.exception.out_of_range.403] key ‘cross_attention’ not found
[TensorRT-LLM][WARNING] Optional value for parameter cross_attention will not be set.
[TensorRT-LLM][WARNING] Parameter layer_types cannot be read from json:
[TensorRT-LLM][WARNING] [json.exception.out_of_range.403] key ‘layer_types’ not found
[TensorRT-LLM][WARNING] [json.exception.type_error.302] type must be string, but is null
[TensorRT-LLM][WARNING] Optional value for parameter quant_algo will not be set.
[TensorRT-LLM][WARNING] Optional value for parameter kv_cache_quant_algo will not be set.
[TensorRT-LLM][WARNING] [json.exception.out_of_range.403] key ‘num_medusa_heads’ not found
[TensorRT-LLM][WARNING] Optional value for parameter num_medusa_heads will not be set.
[TensorRT-LLM][WARNING] [json.exception.out_of_range.403] key ‘max_draft_len’ not found
[TensorRT-LLM][WARNING] Optional value for parameter max_draft_len will not be set.
[TensorRT-LLM][INFO] Initializing MPI with thread mode 3
[TensorRT-LLM][INFO] Initialized MPI
[TensorRT-LLM][INFO] MPI size: 1, rank: 0
I0206 15:23:04.971970 721 model_lifecycle.cc:838] “successfully loaded ‘tensorrt_llm_bls’”
Special tokens have been added in the vocabulary, make sure the associated word embeddings are fine-tuned or trained.
I0206 15:23:06.683378 721 model_lifecycle.cc:838] “successfully loaded ‘postprocessing’”
I0206 15:23:06.690691 721 model_lifecycle.cc:838] “successfully loaded ‘preprocessing’”
[TensorRT-LLM][INFO] Rank 0 is using GPU 0
[TensorRT-LLM][WARNING] The value of maxAttentionWindow cannot exceed mMaxSequenceLen. Therefore, it has been adjusted to match the value of mMaxSequenceLen.
[TensorRT-LLM][INFO] TRTGptModel maxNumSequences: 1
[TensorRT-LLM][INFO] TRTGptModel maxBatchSize: 1
[TensorRT-LLM][INFO] TRTGptModel mMaxAttentionWindowSize: 2048
[TensorRT-LLM][INFO] TRTGptModel enableTrtOverlap: 0
[TensorRT-LLM][INFO] TRTGptModel normalizeLogProbs: 1
[TensorRT-LLM][INFO] Loaded engine size: 15324 MiB
[TensorRT-LLM][ERROR] 1: [stdArchiveReader.cpp::stdArchiveReaderInitCommon::42] Error Code 1: Serialization (Serialization assertion safeVersionRead== kSAFE_SERIALIZATION_VERSION failed.Version tag does not match. Note: Current Version: 0, Serialized Engine Version: 239)
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Environment
Operating System + Version:
NAME=“Amazon Linux”
VERSION=“2”
ID=“amzn”
ID_LIKE=“centos rhel fedora”
VERSION_ID=“2”
PRETTY_NAME=“Amazon Linux 2”
ANSI_COLOR=“0;33”
CPE_NAME=“cpe:2.3:o:amazon:amazon_linux:2”
HOME_URL=“https://amazonlinux.com/”
SUPPORT_END=“2026-06-30”
