I’m trying to convert an model using trtexec on Orin Nano 8GB. The conversion succeeds with an input resolution of 320×576, but fails when the resolution exceeds this size. Below is the log:
[01/01/1970-10:14:52] [W] [TRT] Tactic Device request: 144MB Available: 136MB. Device memory is insufficient to use tactic.
[01/01/1970-10:14:52] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 51 due to insufficient memory on requested size of 150994944 detected for tactic 0xa40cb43c296a36a8.
[01/01/1970-10:14:52] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 52 due to insufficient memory on requested size of 150994944 detected for tactic 0x5d067c18f40c23e3.
[01/01/1970-10:14:52] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 53 due to insufficient memory on requested size of 150994944 detected for tactic 0x263a38afd75e3a43.
[01/01/1970-10:14:52] [V] [TRT] /feature/dino/output_conv1/Conv (CaskConvolution[0x80000009]) profiling completed in 0.27668 seconds. Fastest Tactic: 0xd15ea5edd15ea5ed Time: inf
[01/01/1970-10:14:52] [V] [TRT] Skipping CaskFlattenConvolution: No valid tactics for /feature/dino/output_conv1/Conv
[01/01/1970-10:14:53] [W] [TRT] Engine generation failed with backend strategy 2.
Error message: [optimizer.cpp::computeCosts::4151] Error Code 10: Internal Error (Could not find any implementation for node /feature/dino/output_conv1/Conv.).
Skipping this backend strategy.
[01/01/1970-10:14:53] [E] Error[2]: [engineBuilder.cpp::makeEngineFromSubGraph::1879] Error Code 2: Internal Error (Engine generation failed because all backend strategies failed.)
[01/01/1970-10:14:53] [E] Engine could not be created from network
[01/01/1970-10:14:53] [E] Building engine failed
[01/01/1970-10:14:53] [E] Failed to create engine from model or file.
[01/01/1970-10:14:53] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100300] # ./trtexec --onnx=/home/nvidia/fs-352-640.onnx --saveEngine=/home/nvidia/test.engine --fp16 --verbose --builderOptimizationLevel=4
Thanks in advance for your help.
Best regards
Please try --builderOptimizationLevel=5
to see if it can work.
If the flag doesn’t work, could you share the model with us so we can check it further?
I tried and it didn’t work.
Here is the model:
This is a large model.
Could you run trtexec with --verbose
to see if you are running out of memory?
I think I’m running out of memory. Before the error occurred, it printed a long list of Skipping tactic xx due to insufficient memory on requested size of...
Does this mean the model can’t be converted? Is there any workaround for this?
The model is too large to run on the Orin Nano 8GB.
We got this error when deploy the model with INT8 mode:
$ /usr/src/tensorrt/bin/trtexec --onnx=fs-352-640.onnx --int8
[04/10/2025-07:11:40] [W] [TRT] Tactic Device request: 1218MB Available: 716MB. Device memory is insufficient to use tactic.
[04/10/2025-07:11:40] [W] [TRT] UNSUPPORTED_STATE: Skipping tactic 0 due to insufficient memory on requested size of 1277224960 detected for tactic 0x0000000000000000.
[04/10/2025-07:11:41] [E] Error[10]: IBuilder::buildSerializedNetwork: Error Code 10: Internal Error (Could not find any implementation for node {ForeignNode[/Concat_333_output_0.../Concat_335]}.)
[04/10/2025-07:11:41] [E] Engine could not be created from network
[04/10/2025-07:11:41] [E] Building engine failed
[04/10/2025-07:11:41] [E] Failed to create engine from model or file.
[04/10/2025-07:11:41] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100300] # /usr/src/tensorrt/bin/trtexec --onnx=fs-352-640.onnx --int8
But pass on another Orin NX 16GB mode with the same TensorRT setting:
[04/10/2025-08:24:52] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +4, GPU +1352, now: CPU 6, GPU 2208 (MiB)
[04/10/2025-08:24:52] [I] Setting persistentCacheLimit to 0 bytes.
[04/10/2025-08:24:52] [I] Created execution context with device memory size: 1347.65 MiB
[04/10/2025-08:24:52] [I] Using random values for input left
[04/10/2025-08:24:52] [I] Input binding for left with dimensions 1x3x640x352 is created.
[04/10/2025-08:24:52] [I] Using random values for input right
[04/10/2025-08:24:52] [I] Input binding for right with dimensions 1x3x640x352 is created.
[04/10/2025-08:24:52] [I] Output binding for output with dimensions 1x1x640x352 is created.
[04/10/2025-08:24:52] [I] Starting inference
[04/10/2025-08:25:08] [I] Warmup completed 1 queries over 200 ms
[04/10/2025-08:25:08] [I] Timing trace has 10 queries over 14.3177 s
&&&& PASSED TensorRT.trtexec [TensorRT v100300] # /usr/src/tensorrt/bin/trtexec --onnx=fs-352-640.onnx --int8
Thanks anyway for trying to help! I really appreciate your time and input.
